Intermittent AC blower problem
  • 1 Post By royleroyleroy
Old 26 Sep 2014, 04:43 pm
Default Intermittent AC blower problem
Hi Board,
The AC blower on my 04 will intermittently not work if the car is started
with the switch on, but will eventually come on. The problem has progressed
the last few days to the point that it stops during operation. In searching the
board it appears it could be the blower motor itself or the switch.
Any suggestions on which to start with? Thanks Royleroyleroy
Old 27 Sep 2014, 02:07 pm
Default Re: Intermittent AC blower problem
So, can i assume that since the blower does work intermittently on all speeds,
it's not the resistor on switch? I'm tempted to just replace the motor, as it
doesn't seem like a big project. What sayeth the board?
Old 27 Sep 2014, 02:49 pm
have you tried checking the relay and the ECT?
Old 27 Sep 2014, 04:13 pm
Have you checked the wire connectors going to the blower?
Old 27 Sep 2014, 05:45 pm
I haven't. Thanks, will check both. I do know that on lower speeds the output is very low compared to my other 2005 PT.
Old 04 Oct 2014, 04:06 pm
an update, as I hate it when someone asks for and gets good advice, then
can't be bothered to inform those who helped. I installed a blower motor
from Amazon, which seemed to do the trick. The old one seemed to have
quite a bit of drag when turned by hand. The new one definitely has more
output. Thanks for the help
podo2000 likes this.
intermittent window/airbag problem rob342 Tech & Performance Forum 4 20 Dec 2012 09:52 am
Intermittent problem VetteJohn Tech & Performance Forum 5 01 Aug 2011 03:52 pm
07 Touring - Intermittent Starting Problem DravenGSX Tech & Performance Forum 8 19 Mar 2009 05:58 am
Blower Heater Problem Phewzd Tech & Performance Forum 1 14 Jan 2009 02:45 pm
Intermittent thermometer problem ImLookingThruYou Tech & Performance Forum 3 17 Jun 2008 03:51 pm
