Dead Passenger headlight
Old 29 Sep 2014, 07:17 pm
Default Dead Passenger headlight
Hello people of the internet. As the title states my headlight has quit working. I have changed the bulbs bought a new headlight switch and still nothing. Yes i checked the two fuses under the dash. i did pull out my volt meter and only one fuse is getting power. is there anything else to check? any help would be appreciated thanks.
Old 29 Sep 2014, 07:48 pm
Default Re: Dead Passenger headlight
Well, you found your problem - only one fuse getting power - trace the wire and find the break.
Old 29 Sep 2014, 08:45 pm
What year is your PT Cruiser? Depending on the year of the PT Crusier will allow us to get a good start on what might be the problem!
Old 29 Sep 2014, 08:57 pm
its an 01
Old 29 Sep 2014, 09:15 pm
Yes you do have separate fuses for each headlight. They are the #19 and #20 fuses in the interior fuse box by your left knee when sitting in the drivers seat. They are red 10Amp fuses and you can just pull them out to check if they are good or bad. If you are not sure how to check the fuses just switch the red fuse in #19 with the red fuse in #20 and see if the passenger headlight starts working.
Old 02 Oct 2014, 02:20 pm
Send a message via AIM to crixussteave Send a message via Skype™ to crixussteave
Check the fuse.
after dead battery passenger side windows won't work valcansa General PT Cruiser Discussions 12 06 Jun 2013 10:49 am
PT Cruiser 2005 floor wet passenger and rear passenger help resane Tech & Performance Forum 6 28 Jun 2011 12:25 pm
Issues - Rear passenger blinker out, passenger window not working eobryant Tech & Performance Forum 0 23 Apr 2010 12:51 am
Right Low Headlight + Shifter light Dead HELP ptguycanada General PT Cruiser Discussions 5 12 Oct 2008 05:35 am
Right Low Headlight + Shifter light Dead HELP ptguycanada Tech & Performance Forum 3 15 Jun 2008 12:31 am
