hi, newbie here...2002 PT ignition probs
Old 30 Sep 2014, 07:42 pm
Default hi, newbie here...2002 PT ignition probs
i am here because wife and her new car are 200 miles away..a Haynes isn't now available
'02, turn key, nada...a friend used metal bar to jump 'something', she drove home..turned off car, won't restart...my autozone acct. show no results for relay ...she sees no "ign" fuse at box
can anyone give me an idea where to go first with this?
i thank y'all much
Old 30 Sep 2014, 07:45 pm
Default Re: hi, newbie here...2002 PT ignition probs
PT problems read this FIRST
Old 30 Sep 2014, 09:52 pm
Check fuse #1 ( 30 amp) in the under-hood PDC.
Old 30 Sep 2014, 10:06 pm
Suspect the friend jumped the starter....
Old 01 Oct 2014, 12:26 am
I would suggest checking the wires coming out of the starter to see if one or more of them got burnt and opened up after checking the fuses. Even if the fuse was the problem I would still check the wires as its not a good idea with a bar that could be hitting ground while trying to short 12 volt connectors. This is why remote starter devices are used to help keep wiring circuits from being shorted to ground.
MBC location and ECU probs PETEY_CRUISER Turbo Performance 10 24 Oct 2015 08:45 pm
2002 PT Ignition Problems brn2spr1 General PT Cruiser Discussions 10 29 Apr 2015 07:08 am
'03 PT Cruiser Probs txh976 Tech & Performance Forum 32 18 Apr 2014 09:59 am
2002 PT Cruiser horn honks on ignition mikenguy General PT Cruiser Discussions 0 17 Oct 2010 06:25 pm
MBC Probs PETEY_CRUISER Turbo Performance 5 20 Jun 2003 02:12 am
