Exhaust question ?
Old 02 Oct 2014, 11:00 am
Default Exhaust question ?
I've got a question about the possibilities of removing the pipe behind the conveter with the muffler still connected. So as to remove the pipe and muffler as one piece...is that possible ? Or would you have to remove some of the rear suspension to do that ?
Old 02 Oct 2014, 11:03 am
cruserdad1976's Avatar
Default Re: Exhaust question ?
dosent it go OVER the rear axel???? im not sure you can snake it out with out taking something apart
Old 02 Oct 2014, 11:24 am
Yeah I'm sure it does go over axle. Just asking because a friend works at a dismantlers shop, and my be able to get me a like new factory system ..cheap Was hoping it could be " snaked" through as one piece. Probably not I'm sure.
Old 02 Oct 2014, 04:19 pm
rcktpwrd's Avatar
Smile Re: Exhaust question ?
I changed my exhaust way back in 2001... I didn't have to undo anything with the suspension. Just put the back of the car up on jack stands to get room to work. I think the muffler and pipe that goes over the rear axle is clamped to the mid pipe that goes to the catalytic converter... So it it comes out in two pieces.
Joel
www.rcktpwrd.com
Old 02 Oct 2014, 04:33 pm
Your friend can get it out in one piece when they drop the axle. You can then work on the slip joint on the front of the muffler to get it apart. Its not easy but better than overhead or on your back.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 02 Oct 2014, 06:14 pm
Bit confused here: Were you able to remove your system without separating the muffler and long pipe.. remove it as one complete unit?
Old 02 Oct 2014, 06:56 pm
rcktpwrd's Avatar
I did this way back in 2001 so I don't recall the exact process... but I'm fairly sure it came out in two pieces. Separate the muffler from the long pipe.
Joel
www.rcktpwrd.com
Exhaust question GTLOZER Tech & Performance Forum 19 22 Dec 2013 11:02 am
exhaust question cruisin03pt Tech & Performance Forum 5 03 Sep 2011 11:42 pm
Exhaust Question matt87951 Tech & Performance Forum 2 20 Sep 2004 10:19 am
the weekly exhaust question.. Tw3NTy0n3 Tech & Performance Forum 6 07 Jun 2004 10:26 am
Exhaust question wildwind Exterior Accessories Forum 2 07 Dec 2002 11:23 am
