Rear hatch interchange???
Old 02 Oct 2014, 01:47 pm
Default Rear hatch interchange???
I recently bought a 2008 hatch for my 2001. The old is rusty, the newer one perfect. I bolted on the newer hatch and everything fits well, except the new one will not latch down @ the striker. The are clearly differences between the 2 latch mechanisms. Has anyone come across this and what did you do to fix it? Do I need the 2008 striker also that bolts to the body?
Old 02 Oct 2014, 01:55 pm
Default Re: Rear hatch interchange???
The striker is easy enough to change out. They are held it by two bolts. Changed mine to chrome. You should be able to pick one up pretty easy at a salvage yard. The body panels on either side just pop off to gain access to the latch bolts.
I believe the striker is slightly adjustable also with slots on the striker so maybe you just need to adjust the sticker a bit to make it work with the newer door.
Old 02 Oct 2014, 02:01 pm
striker is not adjustable. It is held in by 2 torx bolts. I'm hoping someone out here has done this
interchange and can shed some light.
Old 02 Oct 2014, 02:43 pm
LionPT's Avatar
I have a 2006 & took the latch out a few months ago to check wiring, the latch has a small amount of play...not sure about the sticker, I've never looked at it.
Old 03 Oct 2014, 04:16 pm
Anyone ever do this?
Old 03 Oct 2014, 05:14 pm
2step's Avatar
In 10 years on the Cruiser forums I've seen a few posts where hatches were changed. I can't tell you what year hatch with what year chassis but I don't recall any latch/striker discussions.
I hope you figure it out and it's something easy/cheap such as an adjustment.
Old 08 Oct 2014, 01:22 pm
Well I have found out that 2001-2004 hatch is unique to itself, and 2005-2010 is unique to itself.
You can use a 2005-2010 hatch on a 2001 PT Cruiser. You must purchase striker P#4589038AB, or use striker from 2005-2010 PT Cruiser . It is a direct bolt in. The newer hatch has a different inner latch assembly which requires using its mate striker.
I am still trying to figure out the outer handle assembly to see if you can use the 2001 pull handle style with the newer latch set-up that is in the hatch already.
Old 08 Oct 2014, 03:32 pm
I 2005, they switched the hatch latch mechanism from manual to electric - did not know the striker also changed....
Old 09 Oct 2014, 01:33 pm
Yes, and if you plug in the 2005+ harness in and try and function the power locks, when you go to lock the car with the key fob, the hatch pops open....uggg, Im trying to figure that out now....
Old 09 Oct 2014, 01:45 pm
Handy_Cruiser's Avatar
If a photo is worth a thousand words, I'm about to say a whole lot.
2001-2004 Latch
2005-2010 Latch
2001-2004 Striker
2005-2010 Striker
Tags
hatch, interchange
Rear Hatch Does't Unlock Georgeorge General PT Cruiser Discussions 4 03 Sep 2012 01:24 pm
rear hatch jimhoysa Sound and Security Forum 0 07 Dec 2010 11:45 pm
Help..rear hatch satownplayer General PT Cruiser Discussions 3 09 Dec 2007 10:21 am
wtb rear hatch josheypt Classifieds: Want To Buy 0 24 Feb 2006 08:19 pm
"flaming" rear hatch.... BumperBob General PT Cruiser Discussions 1 10 Aug 2005 10:07 pm
