MFS Problem.
Old 05 Oct 2014, 04:34 am
BusDriverGuy's Avatar
Default MFS Problem.
Hi all, wasn't sure where to post this,so I'm sorry if it's in the wrong place.
I have a problem with my MFS!! when I turn my headlights on and go to illuminate my dash, I turn one click and my interior lights come on. they only go off in the "off" position. I was wondering if anyone else has had this problem and if so how it was fixed.
Thanks.
Note.. This has only occurred after I had my rear brake discs and pads replaced. I don't know if this has anything to do with it.
Old 05 Oct 2014, 07:10 am
Default Re: MFS Problem.
BusDriverGuy, I don't understand your problem. That twist ring seems to be working as it should. You twist the ring back and forth to illuminate the dash and the last "click" turns the interior lights ON. It seems to working fine the way you describe it.
Old 05 Oct 2014, 08:50 am
LionPT's Avatar
He didn't post what year PT he had, but it sounds like his dash light aren't working.
Old 06 Oct 2014, 09:40 am
Hi again, I thought I had a problem because the interior lights were coming on at the first click of the ring not the very last as it should but after messing about checking fuses and stuff I found the cause of the problem.
My back door was slightly open... I have no idea why this caused the dash and interior lights not to work correctly but it did.
Thanks for your replies though.
Old 06 Oct 2014, 09:42 am
Thanks for getting back to us with the problem...and fix.
Old 06 Oct 2014, 09:46 am
Cheers Crewzin, my next job is to get my foglights working lol and I've seen lots on here about them and UK models. This should be fun...
AC problem became Overheating problem BilltheBrewer Tech & Performance Forum 1 23 Jul 2014 11:31 pm
Window problem and AC problem kaypriest Tech & Performance Forum 30 04 Jul 2014 07:42 am
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
