Fog lights stay on unless left turn on
Old 06 Oct 2014, 03:52 pm
Unhappy Fog lights stay on unless left turn on
I just started having this problem with my pearly. The fog lights will not go off. Finally I noticed that when the left turn is on the fog lights go off. I have a 2004 PT GT High output turbo which I love very much and I am now very frustrated. What can I do to fix this problem?
Old 06 Oct 2014, 04:40 pm
cruserdad1976's Avatar
Default Re: Fog lights stay on unless left turn on
its the multi function switch in the sterring tree
they are bad to go out and cause all sorts of issues its a easy fix( or so i have heard I ahve never done it) thjere are a lot of threads about it but im sure some one will chip in and give you a better answer
Old 06 Oct 2014, 04:57 pm
Lady, you already asked the same question on the 12 page thread that gives you all your answers...
Replace Multifunction Switch w/fog lamps
Old 06 Oct 2014, 05:23 pm
Handy_Cruiser's Avatar
You can also fix the problem completely with little more than a coke can and some glue if you are "handy".
This will show you what causes it and how to fix it cheaply.
The "Handy" Aluminum Can Mod To Fix Fog Lights.
Front Turn Signal Lights Turn On and Off When Applying Brake? Danny7627 Tech & Performance Forum 12 20 Jan 2014 09:42 pm
2006 left turn signal out? Samson Tech & Performance Forum 18 25 Jul 2012 12:44 pm
Had new struts put in, now a noise when I turn either left or right thinkinboutit Wheels, Tires, Suspension 3 19 Dec 2010 11:51 am
Poping on left turn. Hotrod Wheels, Tires, Suspension 8 07 Jul 2006 11:31 am
Way to make radio stay on after turn car off? im4gzs Sound and Security Forum 13 29 Nov 2003 03:35 am
