Engine Mount replacement
Old 10 Oct 2014, 06:48 pm
boonie2's Avatar
Default Engine Mount replacement
Can someone tell the me the correct way to replace the upper and lower Engine Mounts on my 04 basic ? I had my timing belt etc. done afew months ago and i noticed that the engine vibration is pretty noticeable , checked the mounts when the car was at the shop and they "looked fine" but the vibration just feels too much . so I bought an upper and lower mount and ill do it on some nice cool weekend in the driveway...
I remember reading somewhere here about the process but i cant find it anywhere now when i need it Just like to make sure they're lined up properly so i don't wear the others out.. Thanks
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 10 Oct 2014, 09:34 pm
Default Re: Engine Mount replacement
Do you have a repair manual? I would suggest looking up the alignment dimension in the repair manual and measure to see what your dimension is before taking it apart.
Old 12 Oct 2014, 07:00 pm
boonie2's Avatar
Wish i did have a manual , thats why i asked here
Old 12 Oct 2014, 07:17 pm
See if your shop manual is still available from this thread.
Free 01-04 PT cruiser shop manual
Help! Engine Mount replacement rs8 Tech & Performance Forum 18 07 Aug 2015 08:59 pm
Radiator Mount replacement? desiree Tech & Performance Forum 0 25 Jun 2013 11:35 pm
2001 PT - Engine mount replacement needed with Oil pan replacement? SanPT Tech & Performance Forum 14 23 Sep 2012 08:49 pm
engine mount, shifter linkage,control arms replacement sm0421 Tech & Performance Forum 0 17 Oct 2011 01:23 pm
Motor Mount replacement 2002ptcruiserwoody723 Tech & Performance Forum 20 12 Jun 2011 09:19 pm
