Error Code P0551 ?????????
Old 12 Oct 2014, 08:35 am
Default Error Code P0551 ?????????
Thanks for any help on this....got a 2004 PT Turbo that just registered trouble shooting code P0051. I looked it up on what it means and it is - "Power Steering Pressure Sensor Circuit Range/Performance". I have no idea...is this serious? Not sure what it means. Car seems to run fine but worried now that the code is on. Does it warrant taking to the dealer to have checked out? Thanks so much for any feedback. BARANCA
Old 12 Oct 2014, 08:44 am
dalandon's Avatar
Default Re: Error Code P0551 ?????????
I would check the electrical connections first, if you have a pressure sensor it might be faulty
2007 Pastel Yellow PT Cruiser Touring Edition Auto 4 speed, 1 of 2473
Airaid SynthaFlow Cold Air Intake 300-198
UltraGauge EM v1.2
Bridgestone Turanza Serenity Plus 195/65r15
AKA "Banana Car"
Old 12 Oct 2014, 09:16 am
As was just said, check the electrical connections at the switch and also make sure your Power Steering fluid is full. If both are good then it might be time to change out the switch. Pretty easy job but very messy. No way of taking out the old switch and replacing it without loosing a bunch of fluid. If you've never done anything like it, best left to a mechanic. Shouldn't take more than an hour's worth of labor plus the part price.
error code p0551 Ellenlyle General PT Cruiser Discussions 4 24 Jan 2014 02:32 pm
Code P0551 twodees Tech & Performance Forum 3 11 Mar 2013 10:50 am
Code p0551 LNBNDN Tech & Performance Forum 4 26 Oct 2011 08:51 am
P0551 Error code janz Tech & Performance Forum 5 04 Aug 2010 03:26 pm
Code P0551 - How Serious? BB General PT Cruiser Discussions 8 17 Aug 2005 11:12 pm
