Multifunction Switch - Headlights not working - can I use switch with Fogs?
Old 13 Oct 2014, 12:25 pm
Default Multifunction Switch - Headlights not working - can I use switch with Fogs?
I'm trying to repair my daughter's '01 cruiser - the headlight LOW beam's don't work and the fuse is good and I suspect the MultiFunction switch is bad - I looked up the parts and the one for the fog lights is like $58 and the switch for the one without the fogs is $128 - Can I use the cheaper 'fog light' model multifunction switch to operate the headlights and such?
The car is a 2001 base model - no fog lights. The high beams work just fine (and she's been using them for the last 2 days to drive at night), the dash lights work just fine and from what I can tell everything but the headlight LOW beams don't work.
I can't find a detailed diagram that shows the pinouts - I'm assuming they are the same just the fog lights have the additional wires on the plug - can anyone verify that?
Also anyone have a wiring diagram for the '01 'cruiser? I didn't see a relay in the circuit so it looks like there is just a fuse and the MFS in the circuit?
Old 13 Oct 2014, 01:51 pm
LionPT's Avatar
Default Re: Multifunction Switch - Headlights not working - can I use switch with Fogs?
It should work fine. The switch in my 2006 was replaced with a non-fog light switch...I'll be switching it out next month so my fog lights will work. The only thing I've noticed is the dash light dimmer & interior light part of the switch doesn't work, but the dash lights are on, and the interior lights have their own switch anyway. But. mine is a 2006, you might not have the same problem.
Stereo not working after replacing Multifunction Switch talows Sound and Security Forum 0 11 Mar 2014 09:31 pm
wiring up switch for fogs, ran into problem. jrbsr05pt Exterior Accessories Forum 3 03 Jun 2012 09:20 pm
Replaced Multifunction Switch, now no headlights? teamtexas General PT Cruiser Discussions 7 29 May 2012 09:28 am
Multifunction Switch 04 PT w/fogs CYCLONE_06 Classifieds: Want To Buy 0 22 Nov 2009 01:43 pm
Multifunction switch gonzomania General PT Cruiser Discussions 5 23 Feb 2004 05:35 pm
