thermostat housing leak? How to fix it?
Old 16 Oct 2014, 11:16 am
Default thermostat housing leak? How to fix it?
There are a lot of residue around thermostat housing, so I guess it is thermostat housing leak the coolant.
Is it hard to fix it at home?
Do I need to replace both the housing and thermostat?
Thank you
Old 16 Oct 2014, 11:29 am
Default Re: thermostat housing leak? How to fix it?
I just found, the o-ring is on the thermostat,
So I only need to replace the thermostat? right?
Thanks?
Old 16 Oct 2014, 11:50 am
The plastic thermostat housing is known for leaking. I recommend to Replace it.
The lower aluminum mount can warp and/or corrode which can cause the plastic house not to seal properly but this is not as common. You can contact member uptownsport for a lower mount that has been serviced.
Old 16 Oct 2014, 12:02 pm
you have to remove the housing to get to the thermostat anyway, I suggest you get a new housing. dirt cheap and, it's a dorman:
http://www.amazon.com/Dorman-902-308...ype=automotive
2016 Kia Soul Plus Black
Old 16 Oct 2014, 12:32 pm
I would recommend to get the one that is applicated and matches the one for your PT Cruiser. There are 2 types that I am aware of?
The one that was posted is more for a NA and not a Turbo model PT Cruiser. You should take notice of where your the overflow hose is routed to get the correct one. They both can be used but may require re-routing the reservoir hose for the modification of none applicated or matching part.
Old 16 Oct 2014, 01:01 pm
I agree, nitro. but, good luck finding one for the turbo other than a dealer. I see you put one in your's last year. aside from the rerouting of the hose, it would appear it works fine.
Old 16 Oct 2014, 01:12 pm
No not really about 18 plus shipping. And in stock.
I temporarily routed my hose to work but have never liked how it wraps around the filler neck and than to the reservoir. That will be changed with my "BECOOL" aluminum reservoir project when it gets installed.
Old 16 Oct 2014, 04:28 pm
Replace them all. If the base is badly pitted. Take some 120 sand paper on a block with a rag in the opening and sand flat across until you have it pretty smooth. Then put in all the new stuff and reassemble.
Old 16 Oct 2014, 04:36 pm
Thanks all.
Got them replaced this afternoon.
The old gasket is very loose, when I pull the housing, it just fell off.
It is hard to check if it still leak because the leaking coolant evaporates very quickly.
I will monitor the level of coolant in the reservoir.
Old 16 Oct 2014, 04:40 pm
Did you do it? Just curious. May take a day or so to get the level stable from the work. Then you should be able to tell how your doing.
thermostat housing leak? sponge9012 Tech & Performance Forum 9 17 Jun 2014 11:27 am
Car temp climbing after thermostat and thermostat housing replaced. superjew78 General PT Cruiser Discussions 23 04 Jun 2014 02:37 pm
I stripped my thermostat housing! OneLeggedPuke General PT Cruiser Discussions 8 23 Jan 2014 12:07 pm
thermostat housing gasket soyomb General PT Cruiser Discussions 4 06 Feb 2013 09:21 pm
Thermostat housing cowboyinboxers Tech & Performance Forum 11 20 Oct 2012 06:51 pm
