Very Low Oil Died and Won't Start
Like Tree3Likes
Old 16 Oct 2014, 03:56 pm
Default Very Low Oil Died and Won't Start
I ran my 2003 pt low on oil and it just lost power and died! The car still turns over, so I assume it didn't seize, but still won't start.
Any of you experts got an idea of where to start?? I would love to hear your suggestions.
Mahalo! (thanks)
Old 16 Oct 2014, 04:20 pm
Default Re: Very Low Oil Died and Won't Start
Remove the cam sensor and crank while watching the magnet to see if it turns.
Old 16 Oct 2014, 04:39 pm
Danny that may be a long way around a problem? Read what he described and what triggered it.
As always scan the OBDII port, but in this case don't look at or respond with the codes. You will have way to many that are most likely not directly related but simply activated because the engine failed to start. You must clear them and than try again to start the engine only 5 cranks no more if possible. Than recheck the codes. Write them all down and look each one and what they represent and think about which ones you can rule out by your description of the no start. What will be left may be the problem area's to start checking.
If you do not have skills to do this don't waste your time or ours seek a good mechanic or better a Auto Technician trained in diagnostic skills with CANbus and OBDII..
By all means please read this!
PT problems read this FIRST
Old 16 Oct 2014, 05:47 pm
This is a check to see if timing belt broke...
I agree that it would seem if engine turns over, that engine didn't seize...
Old 16 Oct 2014, 06:24 pm
Mahalo! (thanks)
Those are the two key words.
If he had said just "died" I may have suspected more of a timing belt first off.
Old 16 Oct 2014, 06:47 pm
My reason for going there was that I figured that they found out the oil was low, only after it died. Rather than the dinging no oil pressure with oil light on and died.
Old 16 Oct 2014, 08:11 pm
Ok I just read what members post first and not try to use my crystal ball.
Old 16 Oct 2014, 08:48 pm
Well it's what they didn't say that you got to look at sometimes. If it had died of lack oil pressure. We would more than likely heard about the dinging and oil light in the description. Although Lack of oil is important and alarming. More times than not it's discovered during another problem. While not being the current problem.Just my experience with people. Maybe I would have done well in psych classes. Not a subject easily mastered by all.
Old 16 Oct 2014, 09:13 pm
Well it's what they didn't say that you got to look at sometimes. If it had died of lack oil pressure. We would more than likely heard about the dinging and oil light in the description. Although Lack of oil is important and alarming. More times than not it's discovered during another problem. While not being the current problem.Just my experience with people. Maybe I would have done well in psych classes. Not a subject easily mastered all.
Agree.
I would think that if timing belt broke, it could well be described as "lost power and died".
Old 16 Oct 2014, 10:46 pm
cruserdad1976's Avatar
didn't some one say if the oil pressure is low it will not start??? and yes I know that low oil is not the same as low oil pressure
Died, Won't Start, No Codes...HELP! JDB Tech & Performance Forum 12 19 Jul 2014 11:53 pm
01 2.4 died and won't start eagle88 Tech & Performance Forum 8 03 Mar 2014 10:14 pm
2002 PT died & will not start KimT General PT Cruiser Discussions 20 16 Mar 2012 10:05 pm
Car died, wont start! HELP PLEASE!!! Zerotolerancecustoms Tech & Performance Forum 8 15 Aug 2009 03:42 pm
