clicking. ticking. confusion..
Like Tree2Likes
Old 19 Oct 2014, 07:19 pm
Default clicking. ticking. confusion..
Hi! My first post to this page. So excuse me if I dont know exactly what to do l
Ok I have an 02 pt cruiser. Auto. 106k. Owned for 11yrs.
Recently picking my son up from school i randomly got a low rough idle. Almost died. Found a bad egr valve gasket. After replacing that I now have a clicking...or ticking... sometimes it does it in idle... while coasting the sound stops...as soon as I touch the gas it starts clicking. I thought it was my lash adjusters/lifters. So I checked those. They seem fine.
Im at a loss..... help!!
Old 19 Oct 2014, 07:33 pm
Default Re: clicking. ticking. confusion..
Does the clicking increase when you step on the gas or is it the same?
Old 19 Oct 2014, 07:36 pm
It does slightly increase. And as soon as I let it coast it goes away.
Old 19 Oct 2014, 07:56 pm
It sounds like the leak detection pump (NVLD system) is causing the clicking sound. Did you double check to make sure you hooked everything up correctly at the EGR valve after you replaced the EGR gasket?
Old 19 Oct 2014, 08:04 pm
Ive triple checked lol. Would an exhaust leak cause a clicking?
Old 19 Oct 2014, 08:09 pm
Was the clicking sound there before you replaced the EGR valve gasket?
Old 19 Oct 2014, 08:12 pm
No. Iafter the gasket was replaced. I started it amd heard a not pleasant sound. Then clicking.... its a consistant sound too. Rhythm.
Old 19 Oct 2014, 08:14 pm
Is your engine light on and if so what are the engine trouble codes?
Old 19 Oct 2014, 08:18 pm
Not throwing any codes. ... ive been told my injectors might be making it as well
Old 19 Oct 2014, 08:27 pm
Can you tell where the noise is coming from?
P1390 confusion recoveryharryp Tech & Performance Forum 2 22 Sep 2013 04:42 pm
Double DIN confusion... JD78 Sound and Security Forum 11 06 Jun 2013 11:15 am
HOAT confusion! mdfrodolives Tech & Performance Forum 18 02 Sep 2012 06:16 pm
Ticking/Clicking noise Afitch628 Wheels, Tires, Suspension 4 28 Apr 2011 08:45 am
Cruizin' Confusion cruisergeo General PT Cruiser Discussions 1 28 Feb 2003 11:06 pm
