Internal Heater/vent controls
Old 20 Oct 2014, 08:36 am
Default Internal Heater/vent controls
General question....
When you have the vent selector on floor/defrost (the one that shows air blowing on your feet and front window) and have the far right control on recirculate...and you then turn the vent selector to full defrost on window, does your far right control knob automatically rotate over to outside air intake?
If this IS a feature ... Why? If not, I may have a problem here.
388,200 miles as of 6/4/20 '01 PT Cruiser automatic Original (Engine, Transmission, Power Steeering Pump)...3rd Radiator and Fan (with added fan toggle switch mounted inside of car)...3rd Crank Sensor, 2nd Cam Sensor, 3 Timing Belts replaced (1st at 140,000 the 2nd at 345,000 the 3rd at 369,000 due to tensioner fail), 1 Rack and Pinion, 1 water pump at 345,000, 2 alternators - 1 at 345,000 and 1 at 384,000) 4th Watts Link, Serpentine Tensioner at 369,700, New front and rear Brake Calipers at 388,000.
Old 28 Oct 2014, 10:26 am
Default Re: Internal Heater/vent controls
I just wanted to see if my initial question confused everyone since a lot of people have viewed but did not reply.
I also am wondering if the air vent controls are tied to the vacuum system?
Old 28 Oct 2014, 10:39 am
Yes when you have it on closed circulation and you swap to defrost, it automatically flips to pull outside air.
Old 28 Oct 2014, 03:52 pm
randyincctx's Avatar
Post Re: Internal Heater/vent controls
Yes,all PT Cruisers climate controls do that.......Supposedly because outside/fresh air typically has less condensation/humidity than recirculated 'cabin air'.
I've actually been waiting for someone to come up with a modification for this feature.....It could possibly be done by cutting/grinding/removing the metal 'armature?' from the rear of the control knobs that control and/or blocks-out full operator selection,or control of the FRESH/RECIRCULATE modes.
Aka:~KILLER~
UG~! Heater Vent Control Knob Issue 2008 Sarasmiles General PT Cruiser Discussions 3 27 Jun 2014 06:44 pm
CHROME / ALLOY AIR VENT CONTROLS fastdel Classifieds: Want To Buy 0 19 Jul 2009 10:18 am
heater controls 4b316 Tech & Performance Forum 1 11 Jul 2009 07:25 am
Internal CD Changer Jammed!!!! PTKollar Sound and Security Forum 3 19 Sep 2005 11:56 am
"Internal Transmission Problem" ??? yobiebs General Turbo Discussions 18 21 Oct 2003 11:17 pm
