Timing belt life span
Old 20 Oct 2014, 07:05 pm
Question Timing belt life span
I own a 2001 PT Cruiser Limited with the 5-speed stick. I changed the belt at 99,999 miles, it has 156,000 on it now. Was wondering the life span in years on the belt. Does anyone have any idea? I've added a 4 to 2 to 1 Hedman header, Airaid filter and Airaid throttle body spacer. Love the car.
Old 20 Oct 2014, 07:10 pm
Default Re: Timing belt life span
right around the 100,000 mark. so you should be good to around 200,000.
2016 Kia Soul Plus Black
Old 20 Oct 2014, 09:54 pm
According to the box, the blue Gates Racing timing belt has 3x the life of a regular belt. Well, 300,000 miles seems like a lot!
Old 21 Oct 2014, 07:54 am
I'm at 190,000 on my replaced one now. I don't know the brand of it. This will be my next big PT enhancement after winter tires.
388,200 miles as of 6/4/20 '01 PT Cruiser automatic Original (Engine, Transmission, Power Steeering Pump)...3rd Radiator and Fan (with added fan toggle switch mounted inside of car)...3rd Crank Sensor, 2nd Cam Sensor, 3 Timing Belts replaced (1st at 140,000 the 2nd at 345,000 the 3rd at 369,000 due to tensioner fail), 1 Rack and Pinion, 1 water pump at 345,000, 2 alternators - 1 at 345,000 and 1 at 384,000) 4th Watts Link, Serpentine Tensioner at 369,700, New front and rear Brake Calipers at 388,000.
Old 21 Oct 2014, 10:19 am
cruserdad1976's Avatar
id say trying to get to 300,000 on a belt is maybe just pushing it a tad
Old 21 Oct 2014, 10:57 am
The replacement of any belts by the OE is based on a new vehicle and the set scheduled recommend replacement periods. The information by most OEs is up to 100k miles.
You must account for age in years and general normal expected wear when considering the life expectancy of any part after the OE no longer has recommended parts replacements schedules.
IMHO most parts will age and wear about 25% faster as the vehicle also ages in years and miles outside the 100k mark.
Old 21 Oct 2014, 12:13 pm
the fact he has a manual trans also puts more stress on the belt, IMO
when mine broke, it happened when a truck pulled out in front of me on a slippery wet street. i was moping along ~30mph in 3rd gear. truck pulled out, i hit the brake a split second before the clutch(panic stop, no choice). tires locked, motor stopped, belt snapped.
Old 21 Oct 2014, 01:12 pm
Cool Re: Timing belt life span
Thanks for the info. ROB 342, How many miles on your PT when your belt broke? Did it do any head or valve damage? I've had one clutch replaced plus 2 PCM's.
Old 21 Oct 2014, 03:01 pm
Vlefaive's Avatar
So I had mine done at 60,000 miles .. It'll be good till 160,000 miles ?
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 21 Oct 2014, 03:03 pm
should be I trhink the after market belts may be a little better than tyhe factory ones but i have nothing to base that on
New here. average life span of head gasket ? rustytoolss General PT Cruiser Discussions 2 08 Sep 2014 07:30 pm
Timing belt life span ? rustytoolss General PT Cruiser Discussions 2 08 Sep 2014 07:27 pm
Radiator cap's life span LoboMX Turbo Performance 10 03 Apr 2007 11:08 am
