No right front turn signal or parking light
Like Tree2Likes
  • 1 Post By LionPT
  • 1 Post By johnnyzero
Old 24 Oct 2014, 06:05 pm
Default No right front turn signal or parking light
The right front amber bulb on my wife's 2006 PT Cruiser stopped working for both turn signal and parking light.
I replaced the bulb, still no go.
Curiously, when I enable the 4-way flashers (hazard lights), one of the filaments flashes just like it's supposed to.
Before I take a gamble and order a new multi-function switch, I figured I'd post here to see if anyone had any thoughts/advice.
Thanks in advance,
JohnB
Old 24 Oct 2014, 06:14 pm
LionPT's Avatar
Default Re: No right front turn signal or parking light
Try wiggling or use a test light on the socket wires with the blinker on...sounds like a loose wire. Since you didn't mention the right rear, I assume it's working...you might just need to replace the socket.
Old 24 Oct 2014, 06:30 pm
Thanks for your reply.
Since the "blinker" filament flashes just fine when the 4-ways are on, wouldn't that rule out a bad socket or loose wire?
The parking lights & turn signals are both controlled by the multi-function switch, whereas the 4-ways are controlled by a separate dash-mounted switch. This is why I suspect the MFS.
btw, the socket is clean as a whistle (no corrosion), and I've already tried lots of jiggling to see if it made any difference.
Old 24 Oct 2014, 06:41 pm
LionPT's Avatar
If the MFS was bad...shouldn't the whole right side be bad, not just the front..?? If the socket is good, I would remove the steering covers & check the plug that goes into the MFS for a burnt wire.
Old 24 Oct 2014, 06:57 pm
Good point. You're right: it's very unlikely that there are separate contacts/feeds for front and rear.
I'll try that tomorrow when I've got daylight, and post back here. I'm also gonna break out my voltmeter & do some more checking at the socket.
From what I've read, the '06 had a lot of MFS- and turn signal-related issues. I'm really hoping it's not a problem with the TIPM, which is big $$$'s to replace.
Old 04 Nov 2014, 04:21 pm
Solved. It turned out to be a bad ground wire to that connector/socket.
I used a self-piercing connector to splice to the existing ground wire at the socket end, and then I snaked my new wire up thru the wheel well and connected it to a grounded bracket bolt in the engine compartment.
Everything works great now.
Old 04 Nov 2014, 04:44 pm
LionPT's Avatar
Old 04 Nov 2014, 05:36 pm
cruserdad1976's Avatar
Thanks fopr the update
Old 04 Nov 2014, 05:44 pm
Good diagnostics and thanks for posting the cure....
Front Turn Signal Lights Turn On and Off When Applying Brake? Danny7627 Tech & Performance Forum 12 20 Jan 2014 09:42 pm
LED turn signal light bulbs agr1233 Tech & Performance Forum 3 10 Jan 2013 07:06 am
Right front turn signal not working rctjroy Tech & Performance Forum 3 15 Sep 2012 04:26 pm
Turn signal & stop light gonzomania General PT Cruiser Discussions 12 25 Apr 2004 01:18 pm
Help removing front turn signal reflector. GT_Firebreather Exterior Accessories Forum 7 28 Jul 2003 02:14 pm
