Sylvania Silverstar Light Bulbs
Like Tree7Likes
Old 06 Nov 2014, 04:41 pm
boonie2's Avatar
Default Sylvania Silverstar Light Bulbs
Word to the wise! DO NOT PUT THESE BULBS IN YOUR TURN SIGNALS OR TAIL LIGHTS !!!!!!!!!!!! they WILL melt the inside of your lenses ...
someone in one of the posts the other day mentioned that so i went out to check my lenses and sure enough they were melting .
We hardly ever drive the car at night , with the tail lamps always burning . so all that heat was mainly from just braking and standing at stop lights ... these bulbs have only been in for a month or so , so beware
ColTED, JoeX and Gkon like this.
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 06 Nov 2014, 05:09 pm
Default Re: Sylvania Silverstar Light Bulbs
wow thanks for the info!
Gkon likes this.
Old 06 Nov 2014, 05:13 pm
Yikes man. thanks for the heads up!
Gkon likes this.
Old 06 Nov 2014, 06:09 pm
rckstein's Avatar
These were my posts in the other thread as I had the same thing happen to both my taillight lenses:
I can tell you from personal experience do not use the Sylvania SilverStar bulbs, they burn hotter because they are a whiter light, and they will melt the plastic housings of the taillights. I have not had any problems using the SilverStar bulbs for headlights or driving lights and I think that is because those enclosures are larger and dissipate the heat better. Luckily Sylvania reimbursed me for the destroyed taillight housings. They wanted them for testing and their lab confirmed that the bulbs can cause damage in some installations.
Originally Posted by CREWZIN
"They also had a commercial on TV telling anyone that used Sylvania Silverstar bulbs to go on-line to fill in a class action against the company. Like you i have them on the headlights and fog lights on my PT without a problem but filled out the forms for the class action and awaiting the outcome."
Thanks for this info! I did not know about the lawsuit, but I have now filed my claim, below are the links and all claims must be filed by 11/14/14, for anyone else that has purchased any of the Sylvania covered products:
https://autolightclaims.com/mainpage/Notice.aspx
I would advise you to contact Sylvania Customer Service and explain what happened. I did and they refunded me for replacement lenses as well as replacement sockets because their bulbs burned them as well. Good Luck!
Old 06 Nov 2014, 08:41 pm
boonie2's Avatar
Right ! you got me thinking about mine ! they're melted but not ruined , I appriciate the heads up
just sucks that they continue to sell those , KNOWING they burn too hot !
Old 06 Nov 2014, 09:58 pm
rckstein's Avatar
Here's what the SilverStar bulbs did to the sockets on my PT, besides melting the lenses. These are not the original sockets to my PT but had been replaced about (3) years ago, note the burnt color. I think the bulbs had been in use about (2) months before I noticed the problem:
You gotta figure that it would be virtually impossible for any bulb manufacturer to test their products in each and every housing that is manufactured to see how they perform. So my take on it is that they will deal with the complaints that come in, like mine and settle it then. Under most circumstances the SilverStar bulb may be fine, in a larger housing, but in the PT the bulb compartment for the brake bulb is very small so the heat builds up and therefore melts the housing. When I had contacted them when I had my problem, they wanted me to send them the lenses and bulbs so they could test them under real conditions. They put a thermocouple inside the bulb compartment, fixed the hole and then illuminated the bulbs to see how much and how fast the heat builds up inside. The results probably surprised them, too!
Old 07 Nov 2014, 02:11 pm
Thanks for the heads up, OP!
what about the Silverstar Ultra headlight bulbs, anyone had the same problem?
Old 07 Nov 2014, 02:27 pm
rckstein's Avatar
I have used the SilverStar bulbs on my PT for the headlights and driving lights, for several years now, without any problems and I think they are ok in those housings because they are larger and dissipate the heat better than the taillights.
ColTED likes this.
Old 07 Nov 2014, 03:05 pm
Thanks for the reply!
Old 07 Nov 2014, 03:31 pm
boonie2's Avatar
WOW Rckstein thats a definate fire hazzard !!!!!!!!!!!!
Caution When Using Sylvania ST SilverStar Bulbs rckstein General PT Cruiser Discussions 14 11 Sep 2013 09:50 am
LUMINICS head light and fog light bulbs 03baggedturbo Vendors & Buyers Forum 8 22 May 2008 08:36 am
SilverStar Bulbs ronnie sox General PT Cruiser Discussions 11 10 Mar 2005 12:44 pm
LUMINICS head light and fog light bulbs 03baggedturbo Classifieds: For Sale/Trade 0 12 Dec 2004 09:05 pm
silverstar bulbs rszappa1 General PT Cruiser Discussions 9 15 Jun 2004 03:29 pm
