Mutiple Codes?
Like Tree3Likes
  • 1 Post By ptcruisersteve
  • 2 Post By NitroPT
Old 08 Nov 2014, 10:46 pm
Default Mutiple Codes?
Bought the 2004 Cruiser 2 months ago from a used car dealership. had it 2-days and it started to run hot, took it back and they worked on it, said they replaced the radiator. as the tempetures started cooling off, I noticed the check engine light on, checked it and it said thermostat below regulated tempeture, well I really didn't do anything about it, well driving it around town today it starts jumping and shaking and stalling out going up hills, I borrowed my step dads code reader and got theses codes--P0128, P2074, P0137, P0138, P0123. Really not sure whats going on here, I work on air conditioners for a living, any help would be great. ( I think Im going to take it to the dealership where I bought it from and see if they took thermostat out and left it out) Maybe that's whats causing all theses issues as the tempeture drops off.
Old 09 Nov 2014, 12:02 am
Default Re: Mutiple Codes?
You can just search on those codes...
P0123 is throttle position sensor..
P0128 is coolant too cool....
P0137 & 138 are oxygen sensors
P2074-manifold Pressure/throttle Position Correlation - possible vacuum leak
Only 1 is directly tied to the coolant temp....
Old 09 Nov 2014, 12:25 am
I would suggest checking it for intake manifold leaks? I am suggesting that when they replaced the radiator they might have replaced the thermostat and if they did then they might have taken the intake manifold off to remove the hose from the thermostat housing.
I would also suggesting taking the radiator cap off when the engine is cold and see if you get coolant flow in the radiator when its cold.
If they did replace the thermostat they might have replaced it with a lower than normal temperature thermostat. Are you in a low temperature environment?
Old 09 Nov 2014, 01:04 am
Use the scan tool clear the codes run the engine at least one full cycle and than recheck for codes.
The codes you posted looked to me like a stalled engine or no start.
Old 09 Nov 2014, 10:53 am
i live in Mississippi, 50 miles south of Memphis, I cleared the codes and they came right back, I drove around 45 miles and had computer on car, the coolant temp got down to 135 degrees, that's not right I know? ( at least I think) what do I need to replace first? ive always been told that one part could relate to another? making it show bad?
Old 09 Nov 2014, 11:01 am
Did you try taking the radiator cap off when the engine was cold and see if the coolant is flowing immediately?
Old 09 Nov 2014, 11:26 am
'Cause if it does, there is either no thermostat or one that is stuck open.
Old 09 Nov 2014, 11:43 am
If you did not use a Diagnostic Scanning tool and not a viewer or disconnecting the battery the codes you are getting are more than a concern over temperature?
So lets try this again..you need to clear the codes with w Diagnostic scanning tool. Start engine let it idle for 5 minutes re-check codes. Note what comes up and than re-clear them. Go for a short drive of about 15 minute than recheck for codes. If any note them but DO NOT clear them at this point. Continue to drive until the engine light appears. STOP immediately turn engine off and recheck codes and note and then clear them.
You can always look for you cooling system issue but we need to see why
your are getting codes that relate to a failing PCM, connect-ability of the PCM or no start engine sequence?
If you are not using a Diagnostic Scanning tool than I personally can no longer help you and good luck with the members here!
One last thing unless you are in very cold it is almost impossible for the coolant to go that low even without a thermostat with your 45 mile drive. This indicates a bad coolant temperature sensor among your other issues. Your scan tool gets the information from the PCM via the coolant temperature sensor.
Old 09 Nov 2014, 08:21 pm
Thanks guys! I am using a scanning tool, my step dad has one he loaned me. I did find the thermostat was stuck open, it was a fail-safe stat, and it was open, I replaced it and all codes went away except 2, and they were the same-TPS faulty, I replaced it and car seems to be running ok, no engine light is on. the oil light comes on and off at random times? The Haynes book says possibly time to rebuild engine? I hope it is just a faulty sensor? any ideas? You guys are GOOD! Thanks for the help so far...
Old 09 Nov 2014, 08:45 pm
Oil pressure sensor has been known to fail - definitely try before a rebuild!!!
Glad you found most of your problems....
Codes 2pair General PT Cruiser Discussions 4 31 Dec 2013 06:23 pm
Dash codes--not the usual OBD codes--help! chitowncruiser General PT Cruiser Discussions 5 01 Mar 2013 11:56 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
No Codes?? BB General PT Cruiser Discussions 2 13 Aug 2005 08:25 pm
