Heated seat malfunction
Like Tree6Likes
Old 17 Nov 2014, 11:25 pm
Default Heated seat malfunction
Hello everyone……………………….. I need your expert advise on a my heated seat problem.Thinking I had a switch problem as old switch worked intermittently, I replace it with an OEM new one. However the seat still comes on without touching the switch. Sometimes it will not turn off by using the switch until I kill the ignition. Obviously it is not a switch problem but I am not sure what the next step would be. Any ideas before I have to go to the dealer for an expensive repair? Thanks for your responses!
Old 18 Nov 2014, 12:35 am
Default Re: Heated seat malfunction
Does the passenger seat get heated the same time the drivers side does by itself?
Old 18 Nov 2014, 10:03 am
Try taking switch out and see if that shuts seat off - if not, you have a wiring problem.
Old 18 Nov 2014, 11:59 am
Bad relay?
tikitoride likes this.
Old 18 Nov 2014, 09:04 pm
Thank you so much guys for all your responses!…..Relay?? Yep, that's probably the next step….Do you know where it is located? Is it with the interior fuses? Can someone let me know where to look?
Old 18 Nov 2014, 09:07 pm
Thank's ptcruisersteve, the other seat operates properly
Old 18 Nov 2014, 09:09 pm
VNT's Avatar
VNT VNT is offline
look in back of owners manual, will show which cavity the fuse or breaker is that feeds the heated seats, what year cruiser?
VNT
89 Shadow ES 2.5 T2 +20's A555 sold
90 Daytona ES 2.5 T1 A523
90 Datyona Shelby VNT needs work
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
03 PT GT Black 5 sp Stg 1
05 PT GT Silver 5 Spd Conv
Old 19 Nov 2014, 12:52 am
Mine is the 2001 model. After doing more technical research, I have decided to replace the module located under the passenger seat. This controls output levels to both seats and is known to be quite finicky!! I will find someone scrapping their PT and try a different module. I refuse to get parts from the dealer when there are so many PT's being parted out these days and I am cheap! LOL
Old 20 Nov 2014, 10:28 pm
I don't see how module would get power if switch is off - a stuck relay could do that.
Please keep us posted so we know what cure is.
Old 21 Nov 2014, 09:03 am
If you have the wire diagram for the heated seats it would be great if you could display it so others can see how the heated seats work.
Heated seat trouble InfernoGT Welcome New PT Cruiser Members 4 16 Mar 2013 09:30 pm
power seat malfunction OhioKat Interior Accessories Forum 0 09 Oct 2012 06:53 pm
heated seat not working mdskinner731 Tech & Performance Forum 5 19 Mar 2012 08:10 pm
LTD PT no heated seat ejui85 General PT Cruiser Discussions 1 28 Oct 2011 05:37 pm
heated seat JaviPTGT Interior Accessories Forum 4 26 Nov 2008 06:31 am
