Electrical problems in 2003 PT Cruiser, fuses possibly
Like Tree8Likes
  #51 (permalink)
Old 24 Dec 2014, 07:26 pm
LionPT's Avatar
Default Re: Electrical problems in 2003 PT Cruiser, fuses possibly
Originally Posted by Rick_ View Post
I have replaced the MFC switch about 5 times now. Most of the time it would work for an entire day but when I checked in the morning, turn on headlights and hear the all-too-familiar snap of a fuse popping. The main wire hardness that plugs into the MFC has signs of burning/melting but nothing too bad. It looks like this red/pink wire goes to the front right headlight. But if that's the case, why is the headlight still working?
If you've gone through 5 MFS, you need to replace that plug.
More Information for AIRTEX / WELLS 1P1610
  #52 (permalink)
Old 26 Dec 2014, 01:13 am
I have been experiencing the exact same issue as jbander. I too have a 2003 PTC.
I have replaced the MFC switch about 5 times now. Most of the time it would work for an entire day but when I checked in the morning, turn on headlights and hear the all-too-familiar snap of a fuse The main wire hardness that plugs into the MFC has signs of burning/melting but nothing too bad.opping. It looks like this red/pink wire goes to the front right headlight. But if that's the case, why is the headlight still working?
I am at a complete loss here. It's a highly frustrating issue because this is my only car and I cannot drive at night or see how fast I am going.
My #12 interior fuse is fine but replaced it any way. Still no go. It makes me want to take a sledgehammer to the car. *sigh*
THAT will increase resistance and could be why you pop fuses. You need to cut back burned parts of the harness, clean connections and solder in a good connector from a donor car.
  #53 (permalink)
Old 26 Dec 2014, 08:39 pm
Originally Posted by LionPT View Post
The return spring that pulls the cable back out, after you have pulled the hood lever , in the latch itself , Isn't strong enough or the metal part it pulls back is sticking. When You get it open, look in the latch when someone is pulling the latch lever under the dash. It will be self explanatory. I just greased it.
Tags
electrical problems, fuse, lights
Electrical Issues/Problems?.....Check Here First! (PDC Fuses & Relays) randyincctx Tech & Performance Forum 4 05 Mar 2014 07:38 pm
2003 PT Cruiser Transmission Problems bgreen88 Tech & Performance Forum 1 01 Oct 2013 06:39 pm
2003 PT Cruiser Problems RCB General PT Cruiser Discussions 12 05 Jun 2013 09:31 pm
Please Help Numerous problems 2003 pt cruiser Alex939 General PT Cruiser Discussions 8 09 Aug 2010 07:05 pm
2003 Base PT Engine Electrical Problems GaryD Tech & Performance Forum 5 29 Nov 2009 01:51 pm
