Gates thermostat.. not much heat
Old 17 Dec 2014, 05:31 pm
Default Gates thermostat.. not much heat
Has anyone had any problems with Gates thermostats ? I replaced my radiator the fall. I also replaced the radiator cap ,and thermostat, while I was in there. I don't get anywhere near as much heater heat as I use to. Up until this fall, I was still using the original thermostat that was in the car when I bought it 2002.
Old 17 Dec 2014, 06:11 pm
Default Re: Gates thermostat.. not much heat
did you thoroughly bleed the air out of the system when you replaced everything?
2016 Kia Soul Plus Black
Old 17 Dec 2014, 06:15 pm
Yes I did. Used a clear hose, so I could watch for air bubbles. Since I did the work in the fall. My temp gauge is one line below center/ most of the time. It use to be at center.
Car temp climbing after thermostat and thermostat housing replaced. superjew78 General PT Cruiser Discussions 23 04 Jun 2014 03:37 pm
Gates Blue Belts VNT Tech & Performance Forum 25 11 Oct 2013 06:29 pm
Replaced Thermostat 06 PT Getting Engine Light ERROR P0128 Coolant Thermostat aluisi Tech & Performance Forum 1 20 Nov 2012 06:47 pm
Timing belt kit/GATES Part # TCKWP265C PTCruzing Turbo Performance 21 16 May 2011 09:35 pm
