Drivers side window stopped working on wife's 2006
Like Tree5Likes
  • 5 Post By xwing777
Old 27 Dec 2014, 07:13 pm
xwing777's Avatar
Default Drivers side window stopped working on wife's 2006
My first thought was fuse but when i tested all the others worked. So i begin testing the switch and power was there, and switch was throwing power to proper terminals. I then removed the door panel to get to the window motor.
I tested at the harness connector and had power there. I then thought about replacing the window motor but upon closer inspection, the harness going into the motor had a stress break inside the rubber connector.
Carefully cutting away the rubber i was able to solder and shrink wrap new wire and everything works now. The motor moves up and down with the window and as a result, the wires are constantly bending where it clips on the harness connector that is snapped onto the door.
Just a FYI if yours quit working, check the wires closely before wasting money on a new window motor that wasnt needed.
Front Driver Side Power Window Stopped Working itsjusme Tech & Performance Forum 4 08 Dec 2014 01:24 pm
Drivers Side Door Lock no longer working Judhudson Interior Accessories Forum 13 07 Sep 2013 06:00 pm
2006 PT Cruiser White box that says don't re-attach on drivers side katonit Tech & Performance Forum 10 16 Jun 2011 06:06 pm
Drivers side window and cigarette lighter not working? TurboPTChick General PT Cruiser Discussions 5 23 Jul 2010 08:03 pm
The lock on the drivers side isn't working wasmussen Interior Accessories Forum 10 09 May 2009 08:42 am
