CV Joint/Wrong Part Stick Shift
Like Tree3Likes
  • 1 Post By smartieab
  • 1 Post By 3rcruiser
  • 1 Post By NitroPT
Old 15 Mar 2015, 06:37 am
Default CV Joint/Wrong Part Stick Shift
If you read this post please try to forget it. I learned that A I can't trust a guy it thought I could and B i HAVE to wear my glasses when working on a car. Buddy pulled axle while I was running for lunch and oil. He said was too short to start. I asked if he tried to fit it and the answer I got was yes I lined it up it won't fit. No he didn't line it up in the car but beside old broken one and sent me picture. What I didn't see without my glasses was the wear mark on the shaft that the boot sliding down/off caused. I noticed wear mark this afternoon and tried new one in car and imagine my surprise when it fit. I guess it's a lesson learned. Always double check, don't trust a guy I know is sometimes lazy, and wear my freaking glasses. Thank you to all sorry for th dumb-asserie!
Old 15 Mar 2015, 09:00 am
Default Re: CV Joint/Wrong Part Stick Shift
That axle looks a good deal shorter. Are you implying the automatic pt has a 6" wider differential?
2002 trans interchanges with other years, nothing special about the trans, hubs, or axles. No reason you should have had all that trouble.
Is your old axle 37-7/16" when you compress it? Just curious.
Old 15 Mar 2015, 10:50 am
Is there someone out there that can give me their VIN for a 2002 Auto Tranny so I can compare part numbers. I am starting to wonder if this is a combo of an exploded joint and or wrong axle in box. I think the size diff is too much for an exploded joint but want to compare auto to manual parts with Dealer before taking 4 hour round trip and they only look up by VIN
Old 15 Mar 2015, 10:59 am
i don't have an auto. but is the new axle 37-7/16" compressed? that would rule out the "wrong axle in box" idea, and mean it is infact a correct axle for an auto you have there. advance auto, orielly, autozone, and rockauto all list only that size.
i'm not doubting you that the manual cars axle could be different
Old 15 Mar 2015, 11:19 am
Lessen hear...always try to match and compare the new parts with the old parts before replacing them!
For all others if you want a quality axle set or single axle this would be my recommendation. Very good prices on NEW axles for all model PT Cruisers.
PT Cruiser Axles
Old 15 Mar 2015, 11:28 am
nitro the parts catalog in your link only lists one pass. side axle for the PT
for the PT automatic trans CV axle, it also is the same size/length/part number for a neon.
interestingly, autozone does list two passenger side manual transmission axles for the neon.
http://www.autozone.com/drivetrain/c...03039_0_78656/
http://www.autozone.com/drivetrain/c...02924_0_78656/
Old 15 Mar 2015, 04:12 pm
Re-read original post. Long and short I am a dumbass!
rob342 likes this.
Old 15 Mar 2015, 04:29 pm
reading that and looking at the picture again.... LOLOL!!!
congrats on finding the right axle
i had a friend 'help' me throw a civic back together. same kinda deal. said he torqued the head bolts, i believed him. so i buttoned up the valve cover, reconnected all the wiring, cables, hoses, etc, and when I poured in coolant, it started flowing out the seam between the head and the block. it's OK to have a few dumb friends. they make you feel smarter.
Old 17 Mar 2015, 01:01 pm
if you want it done right you gots to do it yourself..
NitroPT likes this.
first 4 cylinder,it sure aint no 8....2004 2.4 base pt 5 speed manual.live wires,screeming demon coil, stage 1jet chip,strut tower bar,airraid setup..nothing fancy...NO TURBO
Old 17 Mar 2015, 01:04 pm
Got that right......
Or know someone that really knows there stuff!!
lol did you read my latest signature addition?
3rcruiser likes this.
Stick Shift Sticking Jamesfb4 General PT Cruiser Discussions 1 24 Aug 2014 09:46 pm
Yucky Stick Shift BarbieCar General PT Cruiser Discussions 5 02 Jun 2012 06:38 pm
Replacing Shift Stick eryncourtney Interior Accessories Forum 3 27 Apr 2011 02:59 pm
Shift Stick Broken eryncourtney Interior Accessories Forum 2 04 Mar 2011 08:42 am
No stick shift in 07 verts? satellite66 PT Cruiser Convertible Forum 0 03 Jun 2007 03:32 pm
