Changing power steering belt tensioner....
  • 1 Post By Alltorque1983
Old 19 Mar 2015, 06:48 am
Default Changing power steering belt tensioner....
Well I just thought I would rant about it....what a pig of a job! Thinking of asking my three year old to do it next time, no room at all to get my hands in! Feels like I've taken half the engine off so far
Anyway.....rant over, better get back to it
Old 19 Mar 2015, 07:18 am
Handy_Cruiser's Avatar
Default Re: Changing power steering belt tensioner....
Did this on my 2001 Limited. It seemed easiest to remove the inner fender liner and then reach up from under the car. Takes about an hour to do the job.
It's not doing real mechanic work like on a big truck where you can stand between the front wheel and the engine. But it's a pretty standard job when working on one of these little toy cars.
Old 19 Mar 2015, 09:51 am
Still going!!! Have no clue how to get the left nut off the belt tensioner off, getting rather frustrated now!
Old 19 Mar 2015, 02:12 pm
Anyone able to help? Im having real trouble getting this tensioner off! Any info/tips would be great!
Handy_Cruiser likes this.
Old 19 Mar 2015, 02:38 pm
Okay,
Here's a photo of the one on my 2001 limited. I have a 3/8 break-over bar in the slot to take the tension off so I can remove the drive belt. As you can see, it's all pretty easy to get to once the splash shield removed.
Now, in the following image, notice that the bolt holding the tension to the engine is above and slightly to the right of the pulley. The easiest way to get to it is the remove the pulley. So take it off first. Then you should be able to get to that bolt.
Old 19 Mar 2015, 03:10 pm
THese two pages may help also.
Jerry
Old 19 Mar 2015, 03:28 pm
Sorry guys its a 2.0 petrol, the one with the adjuster mounted on a cam plate cover piece
Power Steering Belt tensioner pulley problems Bandit2014 Tech & Performance Forum 11 04 Jan 2015 01:47 pm
Power steering tensioner pulley DODGETHIS Tech & Performance Forum 2 09 Apr 2012 03:22 pm
Belt Squeal in A/C, Pwr Steering & Tensioner Loop hhmorgan General PT Cruiser Discussions 0 24 May 2011 01:37 pm
a/c power steering belt tensioner swanjack Tech & Performance Forum 6 13 Apr 2011 06:51 am
Changing power steering pressure switch hfddirty30 Southeast PT Forum 0 26 Aug 2010 02:51 pm
