Tire pressure light
  • 1 Post By ptcruisersteve
Old 22 Mar 2015, 09:21 pm
2008ptcruzrtouring's Avatar
Default Tire pressure light
Hello all!,
Having some minor issues with Bluey. The tire pressure light won't go off. Tired are all fine, pretty new, as I bought them w 85% tread on them when I bought the car. I can't get this to go off and it keeps chiming at me, it's getting annoying lol. Any ideas as far as resetting the light goes? Also, looking to put in aftermarket dash lights... If I were to "hard wire" them into my car, how could I do so?
Thanks
Eli
Proud owner of a stone white 2008 pt cruiser Custom Series with 92,xxx original miles and counting
Old 22 Mar 2015, 09:28 pm
Default Re: Tire pressure light
When did the tire pressure light come on?
Was there any tire repairs done at the time?
Old 22 Mar 2015, 10:01 pm
Came on in late January. And no. No repairs Done at the time.
Old 22 Mar 2015, 10:48 pm
Have you checked the tire pressure several hours after filling the tires with 32 PSI? Sometimes the tires leak air between the tire and the rim.
Old 23 Mar 2015, 10:48 am
Yea all the tires are good. Tried multiple (7) tire pressure gauges
Old 23 Mar 2015, 10:56 am
ha! i like the repetition. i used four on mine and got four different readings, as off as 10psi!
-the pressure sensors inside the tires commonly go bad. it's not a PT or Chrysler issue, it seems to happen fairly commonly on other makes as well. we had it happen in a pontiac GTP. most of those sensors only come on when you're 25% or more low on air, so odds are, you have a failed sensor. maybe the cold killed it, maybe there was moisture in the rim/sensor that turned to ice on a cold january day that killed it, but the best fix would be to have the sensor inside the rim replaced.
LionPT's Avatar
How to Disable the Tire Pressure Monitor?
Have the sensors checked.
Old 23 Mar 2015, 06:40 pm
Originally Posted by LionPT View Post
I just wish there was a way to get the whole darn system to go off lol
Old 23 Mar 2015, 06:41 pm
Any ideas as far as my lighting goes?
Old 23 Mar 2015, 08:46 pm
soonercruiser's Avatar
Cool Re: Tire pressure light
**AND....
It doesn't have to be the sensors that are bad.
I had put on aftermarket valve caps with the "PT" logo on them.
It seems that I was twisting them on too tight, and one the little "O" rings inside the cap came free and jammed along side the valve, setting off the tire pressure sensor light.
Frank, aka SOONERCRUISER,
Tire Pressure Monitor Light - false reading? zeontestpilot General PT Cruiser Discussions 12 09 Sep 2014 12:18 am
Tire Pressure TaylorMade General PT Cruiser Discussions 15 10 Oct 2013 10:08 am
Tire pressure. Door or tire? Cliff5550 General PT Cruiser Discussions 25 27 Apr 2013 04:29 pm
Tire pressure 1lowufo Tech & Performance Forum 2 10 Mar 2010 09:23 pm
15" tire pressure? Brad Vandrasik Wheels, Tires, Suspension 6 03 Dec 2003 11:22 am
