Battery Warning Light
Old 25 Mar 2015, 08:22 am
Unhappy Battery Warning Light
The battery warning light comes on when driving and occasionally at start. It usually resets after engine is turned off & restarted. The alternator maintains a 14.2 V charge on the battery when the battery warning light is on.
Is there a known common short in the PT Cruisers electrical system?
I've also read on several forums that the ECM could be the culprit.
Before replacing the ECM would it be worth a try to re-flash my existing ECM or Chrysler TSB # 18-007-07. PCM?
2001 Limited Edition. 66k miles, original owner
Old 25 Mar 2015, 08:26 am
Default Re: Battery Warning Light
Before replacing the ECM would it be worth a try to re-flash my existing ECM?
2001 Touring. 66k miles, original owner
You don't say anything about the battery. How old is it?
Get it tested.
Old 25 Mar 2015, 09:06 am
It is 5 months old and has been tested.
Get it tested.
Old 25 Mar 2015, 09:32 am
I would suggest checking the wires going to the generator. Other members have found a small hole rubbed through the braid on the wire harness going to the generator.
The small hole was rubbed in the braid by the CV joint boot! And that rubbed a break in the wires inside the wire loom.
Old 16 Apr 2015, 07:22 am
Question Re: Battery Warning Light
Since the weather warmed up the Battery indicator light has not come on.
The last 2 days when attempting to start the PT there is just a click and removing the key for a few seconds and making a second attempt the starter engages like no problem occurred.
I'm suspecting a wiring problem in the steering column.
Anyone have a suggestion what should be looked at first???
Old 16 Apr 2015, 08:14 am
Sorry...how did the battery get ruled out as the problem??
I do not see where it was properly load tested? I do see that it was purchased 5 months ago but that does not indicate the age or true condition of the battery.
Nitro's way of checking a battery
Old 16 Apr 2015, 08:22 am
Did you check all the wires going to the generator?
Tags
battery light, electronic control module, short, warning light
Intermittent oil warning light pt2 sawdust123 General Turbo Discussions 25 03 Apr 2017 07:41 am
ABS warning light enterlaughing General PT Cruiser Discussions 2 11 Oct 2011 04:16 am
Oil warning light on...oil topped off? wheelgarage Tech & Performance Forum 32 23 Jan 2011 07:54 am
Warning light at acceleration PT-ERA Tech & Performance Forum 8 22 Nov 2005 05:54 pm
brake light warning onyx pt General Turbo Discussions 7 27 Apr 2004 02:51 pm
