So, my wife's CEL came on, she sent me a picture of it and asked why it came on. Not being Kreskin, I checked it when she got home.
The code wa a p0304, misfire on cyclinder 4. The part I need help with is, which cylinder is no. 4. Is it on the drivers side, or passenger side? Dumb question, feel free to flame. 04 turbo. |
It would be good to get more information first.
How many miles on the PT Cruiser? When was the last time the spark plugs and spark plug wires were replaced? You might want to check and make sure the hose going from the PCV to the intake manifold is not cracking or leaking. The hose is known for leaking next to the intake manifold where you can't see it very well. Last edited by ptcruisersteve; 25 Mar 2015 at 10:18 am. |
![]() Quote:
![]() 2006 Touring Edition in Cool Vanilla...aka/Ghost |
PERFECT!
I going to print that to refer to during my next brain cramp! |
found this on a post from 2010.
I had some other threads on this code but thought I'd share the final resolution.... I did the following over the past months... 1) Replaced Valve Cover Gaskets / Spark Plug Well Gaskets as the plugs were very wet (on top near boot) - Code did NOT clear. 2) Replaced Intake Manifold Gasket (upper) Code did NOT clear. 3) Replaced Plugs and Wires - Code did NOT clear. 4) Replace the Coil - Code did NOT clear 5) Replaced the injector (#4) - Code did NOT clear. 6) Replaced the Intake Manifold Gasket (Lower). The gasket was broken for sure - Code CLEARED!!!! I can tell you with certainty that I now know how to take everything apart and what sizes those nuts and bolts are. Off all the things I did, #1 and #6 were the hardest.
2005 Toyota Camry LE Salsa Red (Wife's) 2002 Automatic N/A (Mine) Inferno Red 2016 Kia Soul Plus Black |
You are the beginning stages of solving what may or may not be a problem.
First using a OBDII Scanning Tool access the Diagnostic Connector and check for all DTC. Note them and clear them. IF the light does not reactivate you may have simply had an anomaly. If the light returns before you worry re-check the Diagnostic connector with a scanning tool note the DTC and clear again and then return to this thread you started and report. Going on a random problem mystery "HUNT" like the previous member posted IMO unless some parts were up for preventive or normal replacement is waste of your time and money. You should take the time to read this. ![]() Car Repair Advice Forum= at your own risk |
I only posted that so the op could pretty much eliminate steps 1 through 5, therefore saving him time and money.
if only step 6 remained, it would hardly be a "hunt". for the op: try spraying something like starter fluid around your intake manifold while the car is running. if there's an increase in idle, there's a good chance of a gasket leak.
It does not cover all the possibilities and the original post really gives little to go on. So this is another thread that responses from some members IMO re not really helpful unless.
![]() There just is a sound method of solving problems on vehicles that should be provided. Guessing and what other did to solve their own specific issues reall at this early point don't belong on the thread yet? But hey what do I know right? laughing: Let me provide this thread. ![]() Car Repair Advice Forum= at your own risk |
![]() Quote:
It may just be a random event that threw the code. Anytime I get a code, I first check the code number and then clear it. Then I run the car and see if the code returns. Sometimes they never do. And sometimes they will stick around for a while if I don't clear them even if I know the problem has already been fixed. ![]()
Thread Tools | |
Display Modes | |
