Turbo troubles!
Old 27 Mar 2015, 06:34 pm
Default Turbo troubles!
Hi All- I have an 03 Turbo with 125,000 miles on it. A few weeks ago, it started running very rough. Had plugs replaced. Seemed fine. Last weekend, I got it on the freeway for the first time in about 3 months, and ran it about 15 miles at normal 70 mph. Stopped for breakfast, back on the freeway and ran it up to around 90 mph for about 2 miles. Got off the freeway, waited for a light to change and all of a sudden engine was running rough again--maybe a 50% power loss. After about a mile it cleared up--like clearing your throat. Check engine light was on, so I checked fault code----cylinder 2 misfire---ran fine until last Tues. Ran rough for about a mile then cleared up again. Yesterday, it continued to run rough, so off to the dealer I went. Service guy called this morning."Their diagnostics showed a major compression loss in #2 cylinder-It takes 10 hours to tear the engine down to get to the problem, then they have to figure out if a valve went out, etc., so I'm looking at over $1,000 just to get to the trouble! My question: If this was indeed a compression issue, would it act up intermittently? I think a 10 hour tear down is a bit much--seems like the dealer just doesn't want to mess with it. Seems like a # 2 cylinder misfire is not related to a compression issue. I also have a broken motor mount---would that cause enough vibration to work something loose that shouldn't be loose? Sorry for the long question, but I want to get all of the info out there so I can get input from fellow PT-ers before I go further. I would certainly appreciate any ideas that you all may have. Thanks very much!!
Old 27 Mar 2015, 07:17 pm
Default Re: Turbo troubles!
Did you replace wires with the plugs?
Swap wires between 2&3, and see if problem changes. If not, then swap plugs between 2&3 and see if problem moves.
Old 28 Mar 2015, 03:55 am
I'll try that! Beats a total re-build! Thank you!!
PT GT TURBO TROUBLES LARGENT General Turbo Discussions 2 17 Sep 2013 09:18 pm
pt troubles 05ptgirl Tech & Performance Forum 4 21 Jul 2012 12:23 pm
IAC troubles rob342 General PT Cruiser Discussions 1 16 Jun 2012 01:55 pm
06 troubles Jocko Tech & Performance Forum 4 26 Apr 2012 02:02 pm
Car Troubles PTCMIAH62 General PT Cruiser Discussions 9 07 Sep 2010 11:00 am
