P050B cold start timing
Old 28 Mar 2015, 09:55 am
Default P050B cold start timing
Got a trouble light this morning. P050B cold start timing. Understand supposed to retard the timing until the cat warms up??
I started the car and went inside the house so don't know if any symptoms. Car ran fine when I left with engine light on.
I reset it and when I go out later will see if the light comes back on. The ECM was reflashed about a year or two ago for cold starting issues but never got a P050B before. What should I look for if it returns? As far as I know there is no sensor for this.
Thanks
Mike
Old 28 Mar 2015, 10:48 am
LionPT's Avatar
Default Re: P050B cold start timing
Read this: Weird code P050B
Old 29 Mar 2015, 09:45 am
Thanks for the info.
The good news is after resetting, no code last night or this morning at about 17 degrees.
Seems (doing some research) a lot of things (all expensive) can cause this. The one common in all explanations was the ECM (hope not).
Question though, I put in some Lucas oil treatment a couple days ago to see if itwould help in the oil consumption. I go through a quart every 1000 miles. Thought I'd experiment. Can the extra thickness at low temp have caused it??
Thanks!
Mike
Upon Cold Start in Cold Weather, Loud Noise?? paulrosenthal Tech & Performance Forum 33 01 Oct 2014 09:55 am
Weird code P050B neoplanman Tech & Performance Forum 2 21 Jan 2014 10:51 am
Cold Start ahaddad Tech & Performance Forum 6 29 May 2012 10:02 pm
Timing Belt Was Just Replaced - Oil Warning Light at Cold Start Up ? PURPLE_GT General Turbo Discussions 10 05 Jan 2012 06:58 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
