Changing a Timing Belt, how to 'properly' remove cam sprockets and lock camshafts?
  • 1 Post By Handy_Cruiser
Old 28 Mar 2015, 08:41 pm
Flash619's Avatar
Default Changing a Timing Belt, how to 'properly' remove cam sprockets and lock camshafts?
Hello, Now, I hope I don't get yelled at for asking a question on timing belt replacement 'given there is like 5 threads about it in the howto', but I for the life of me, cant seem to find a good detailed tutorial, on how to remove the cam sprockets and lock the camshafts while retaining the engines timing.
I know when working on some european cars you can lock the cams with a cam lock tool that holds them in place when the sprockets are removed so they dont turn.
Why do I need to remove them? Because I want to change the water pump and the back timing belt cover is in the way...
Also, there seems to be a oil leak on that same side of the engine, and it could be possible that it's the crank seal. If this is the case, how again, would I be able to remove the crank toothed pulley while retaining timing?
I've seen people use a gauge to figure out TDC and everything.... but I feel like there has to be a way to just lock the cams, and lock the crankshaft, and avoid the mess of re timing the entire engine. I could be wrong, but I would expect a better way?
Old 29 Mar 2015, 08:09 am
Handy_Cruiser's Avatar
Default Re: Changing a Timing Belt, how to 'properly' remove cam sprockets and lock camshafts
Use a rubber door stop to wedge between the cam sprockets. Then just loosen the bolts in the center of sprockets.
Here's a photo where someone used a bolt and nut. But this may damage the sprocket teeth. A rubber door stop in this position will be safer:
There are tools to lock the camshafts in place but these are only necessary when using variable timing sprockets. Here's a photo of the locking tool in place with a variable timing setup. The tool is the flat bar with two dowels on it that fit into the holes on the camshafts to hold them at TDS:
The OEM cam sprockets and crank sprocket have timing marks that can easily be lined up. There is no need for an alignment tool when using the OEM sprockets.
Go to this link to read more on this:
Busted_PT project 1
Old 29 Mar 2015, 09:45 am
Flash619's Avatar
Busted_PT project 1
I understand what you're saying.... But if you remove the cam sprockets, without locking the camshafts.... If the camshafts move after the sprockets are removed, the timing marks on the sprockets would be usesless. Am I wrong?
Old 29 Mar 2015, 10:45 am
True as you put it. but timing is useless until you put the sprockets back on anyway. You can't get this wrong when the time comes if you pay attention to the marks. If the crank sprocket is pointing correctly on the trailing edge of the arrowed tooth you are correct. If not move it until it is. Same with the cams. A rubber wedge door stop can be used to foul the cam sprockets for tightening the cam bolts and putting the belt on. I did mine with out any thing. Important thing is to take very clear picks of the timing top and bottom for reference in case you have other issues later to rule out timing. Don't rely on memory.
Old 29 Mar 2015, 11:00 am
Why do you think if you use the flat bar with two dowels on it that fit into the holes on the camshafts to hold them at TDS that the camshafts would move unless you feel the two dowels are not a slip fit keeping the camshafts from moving at all?
Old 29 Mar 2015, 11:15 am
Steve I believe he is talking about without that bar. But To be clear the cams have a dowel that line up in the sprocket. and the crank sprocket has a key that line these up with the sprockets. No need to use the dial gauge if using stock sprockets.Cam lock might make it easier to put the belt on for some.
Old 30 Mar 2015, 10:02 pm
the dcr tool is like 100$.. a bit steep but I am gonna get one eventually...
first 4 cylinder,it sure aint no 8....2004 2.4 base pt 5 speed manual.live wires,screeming demon coil, stage 1jet chip,strut tower bar,airraid setup..nothing fancy...NO TURBO
Old 30 Mar 2015, 10:07 pm
Just make one. Nothing special about it. I'm just too impatient to bother once I'm there. I just do the job and close it up.
timing belt coming off the cam sprockets tmikes Tech & Performance Forum 38 10 Feb 2014 04:07 pm
Changing timing belt. unioncreek Tech & Performance Forum 2 19 Jul 2012 08:41 am
Changing Timing Belt - Jack engine end? wichitavor Tech & Performance Forum 2 17 Jan 2012 09:11 pm
rough idle after changing timing belt on 01 pt EnragedDolph Tech & Performance Forum 2 13 Oct 2010 03:51 pm
