To replace a crank seal, or to hope its not leaking?
  • 1 Post By Busted_PT
Old 04 Apr 2015, 09:19 am
Flash619's Avatar
Default To replace a crank seal, or to hope its not leaking?
So I have this timing belt thing all torn apart, and thats fantastic. However I noticed a lot of black tar like residue around the crank pully, including above it, below it, on the oil pan, etc.. I never notice any oil puddles in my driveway, and there doesnt seem to be any active dripping. So its hard for me to tell if the crank is leaking or not. This would be helpful to know though, because if it is, now is a perfect time to replace it.
However I have no idea of what tools I need for this job, or how to use the tools I would need to begin with.
Any advice?
I'll get some pictures of it (be warned I did some cleaning so my hands wouldnt turn black)
Also I'm aware the timing mark is off, I plan to turn it back once I have it ready.
I'm already replacing the valve cover gasket (the old one fell right out and was completely saturated in oil.... looked like it may had been seeping around the edges too. The RTV was completely gone.)
File Type: jpg 11100710_10155341840860702_1011166771_n.jpg (53.7 KB, 20 views)
File Type: jpg 11120534_10155341840680702_2008273249_n.jpg (65.0 KB, 18 views)
Old 04 Apr 2015, 09:33 am
Default Re: To replace a crank seal, or to hope its not leaking?
Any advice?
I ran into the same thing. I replaced the crank and cam seals. It's the best time to do this. Better safe than sorry. Made my oun tools to do whatever I didn't have far as special tools. It's the same link I previously gave you.
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
Old 04 Apr 2015, 09:53 am
Flash619's Avatar
Thats nice but I dont have the resources to make special tools. I also dont have the proper tools to measure the distance from the block to the crank puley.
Old 04 Apr 2015, 10:02 am
To clean the area I used two tea pots of boiling water poured down over the greasy area, no scrubbing was required.
Do this before removing the crank gear to avoid getting dirt / water in the crankcase.
Some PT Cruisers had cranks that had to much end play and were sliding back and forth causing leaks.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 04 Apr 2015, 10:04 am
Flash619's Avatar
O.O That sounds to be a pretty severe mistake on their end.... Also a potentially unfixable mistake.
Old 04 Apr 2015, 10:22 am
That problem was in newer models. Don't get excited. You would know if that was your problem. It pushes the crank seal out. Massive oil leak. You should check to see if you have a friend or relative to help you that has some mechanical experience. Just to be on the safe side.
You need only a peace of cardboard and a pencil to mark the length on the crank. A hack saw to cut a peace of PVC pipe or steal pipe to use as a push on tool. And some bolts, washers, and nut that can be had at a good fastener store. You are going to need something to put the Harmonic balancer back on with. The rest is standard universal tools needed to do this job. You don't want to be pounding the balancer back on the crank with a hammer.
JoeX likes this.
Old 04 Apr 2015, 12:59 pm
Flash619's Avatar
So I looked it over and actually dont see any leaking..... not sure where it all came from. Perhaps oil was spilled once. That and all the bearings are shot on the tensioner, idler, and water pump, so it could be grease too. :|
On a plus, new belt on and timing is perfect
Old 04 Apr 2015, 01:19 pm
Mine looked like someone had used a grease gun to apply a neat smooth ring of grease around the crank shaft on the oil pump
73 Charger SE
01 Sebring flip
Main Seal Leaking, What to do? Patrick_Dickey Tech & Performance Forum 12 22 Jul 2014 12:12 pm
02 front crank seal murphy Tech & Performance Forum 8 13 May 2013 02:57 pm
Front crank seal oil leak Pt4Me General PT Cruiser Discussions 10 25 Nov 2012 03:27 am
Frt Crank Seal Help please!!! johnmucci Tech & Performance Forum 4 18 May 2012 11:57 pm
hope for me careyk General PT Cruiser Discussions 5 20 Sep 2009 09:59 pm
