PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   General PT Cruiser Discussions (http://www.ptcruiserlinks.com/forum/general-pt-cruiser-discussions/)
-   -   Leak? (http://www.ptcruiserlinks.com/forum/general-pt-cruiser-discussions/56380-leak.html)
denab 06 Apr 2015 07:58 pm
Leak?
what would leak out of 01 cruiser on front passenger side?
rckstein 06 Apr 2015 08:00 pm
Re: Leak?
What color is the liquid?
quicksilverdon 06 Apr 2015 08:04 pm
Re: Leak?
Did you have A/C or defroster on? Condensation is there if it is clear....
Coolant overflow bottle is there too - temperature gauge on 1/2 way?
denab 06 Apr 2015 10:12 pm
Re: Leak?
Do not know what color it was ...dark outside now and on asphalt. A/C-defroster not on.
at stop lights noticed temp gauge lowering!?
quicksilverdon 06 Apr 2015 10:54 pm
Re: Leak?
Don't drive it again until you check coolant level - when engine is cold, open radiator and look in - coolant should be up to brim.
Your temp sensor may have been in air, not coolant, and air does not conduct heat as well, so it reads a lower temp.
denab 07 Apr 2015 10:47 am
Re: Leak?
Well I checked the coolant level and it seems okay....There is no mark where I saw the leak. just once I would like it to be something black and white! Is it Okay to drive?
cruserdad1976 07 Apr 2015 11:07 am
Re: Leak?
if its got collent and oil id say drive it but be mindefull on the pass side is the water pump the over flow bottle the washer resivor
denab 07 Apr 2015 05:41 pm
Re: Leak?
I just took it to the corner store. .4 miles maybe when I csme out (10 min)it was right in middle But I am all hinckey now and everything it has always done I am thinking what???I dont know...
My Pop is looking down and saying what he always said 'Dammit Dena, I told you............' Fill in the blanks gentlemen with daughters! Thanks for the input all. i will keep you informed... ohhh joy!
