Instrument cluster light replacement question
Like Tree4Likes
  • 1 Post By Handy_Cruiser
  • 3 Post By 05RAGTOP
Old 07 Apr 2015, 12:10 pm
Default Instrument cluster light replacement question
Hi fellow PT owners
I have a 2005 PT Convertible, and my "deck lid ajar" indicator light in instrument cluster appears to be burned out. I have been searching forums and cannot find if this particular light bulb is repairable or changeable. In the owner manual it list bulb as "led" and no replacement reference numbers. DID the self check on the instrument panel and all lights work except the deck lid.
Is this light replaceable?
Thanks for your assistance
2005 RED PT Convertible Touring - 38,000KMs
Old 07 Apr 2015, 12:23 pm
Default Re: Instrument cluster light replacement question
1st gen cruisers (2001 - 2005) should be replaceable. check in the "how to" section in tech and performance for instructions.
if I'm not mistaken, the bulb is 74. might as well replace all of the bulbs in the cluster while you're in there.
2016 Kia Soul Plus Black
Old 07 Apr 2015, 02:54 pm
Thanks But reviewing manual it states that the bulb is LED with no indication its replaceable? For the backlite bulbs its shows #74 type
Old 07 Apr 2015, 03:21 pm
I don't have a convertible so we'll just have to wait for someone who does to see if they can give you a proper answer.
Old 07 Apr 2015, 03:22 pm
Handy_Cruiser's Avatar
It can be replaced but you will need a solder pen and some solder.
This photo is the board out of a 1st Gen PT GT cluster. But the NA board looks similar.
Here's a closeup of some of the bulbs:
Old 07 Apr 2015, 03:37 pm
Thanks Handy Cruiser! Leave it to Chrysler to make a simple bulb change very difficult, complete dismantling of instrument cluster! not sure if the led bulb can be purchased from Chrysler guess best to live with bad bulb for now
Old 27 Nov 2016, 05:10 pm
Update: I decided to remove deck lid lock to check the if maybe there was a wiring problem with the open trunk switch: it appeared ok and a did a continuity test and the switch was opening and closing normally. I sprayed the switch area with CRC contact cleaner, and Voila!the open trunk light indicator is now working!
Old 27 Nov 2016, 09:38 pm
It is very uncommon for an LED to die due to age. Most LED bulbs come with a lifetime warranty for this reason. the only reason they would die is if they were overloaded or not properly supplied power and ground to light at all.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Instrument Cluster Light Problem skretz General PT Cruiser Discussions 21 28 Feb 2015 11:25 pm
Flashing red light in black dot within instrument cluster CruiserLady Interior Accessories Forum 4 10 Nov 2012 10:43 pm
Instrument Cluster Replacement JohnBrehm Tech & Performance Forum 10 17 Feb 2011 11:58 am
Instrument Cluster Light Recal? Wicked_PT General PT Cruiser Discussions 17 19 Mar 2009 03:29 pm
Factory Instrument Cluster bulbs Replacement? I Need HELP! HotToyz Interior Accessories Forum 2 20 Sep 2008 08:32 pm
