Does this look right?
Old 09 Apr 2015, 12:58 am
Default Does this look right?
My 01 overheated e few weeks ago and I had a mechanic friend do a few tests and he figured I had a blown head gasket or a cracked head so I pulled everything apart. It looks like I just had a worn out water pump. After having the head milled, I got the head back on and the cams back in but I'm having a little trouble lining up the cams. Here are a couple of pictures. Does this look right to you?
When I have the straight edge across the cams, the center marks on the cams are just slightly higher than the marks on the outer edge of the cams. I don't want to have to do this again.
I'd like your opinions before I close this up.
Old 09 Apr 2015, 02:07 am
dalandon's Avatar
Default Re: Does this look right?
Check out this thread
Timing belt replacement on wifes 2006 NA
2007 Pastel Yellow PT Cruiser Touring Edition Auto 4 speed, 1 of 2473
Airaid SynthaFlow Cold Air Intake 300-198
UltraGauge EM v1.2
Bridgestone Turanza Serenity Plus 195/65r15
AKA "Banana Car"
