How to reinstall harmonic balancer?
Old 09 Apr 2015, 06:40 pm
Flash619's Avatar
Default How to reinstall harmonic balancer?
Ok, so I have the harmonic balancer removed, but I cant, for the life of me, find a bolt in any kit made by mankind that is long enough to reach the internal threads in the crankshaft. I went to Festenal and even they cant get me a bolt thats much longer than the original, so I have to ask, how does one actually get this thing back together aside from a block of wood and a rubber mallet? I dont very much feel like using that method given it can cause damage to components so whats my alternative?
I have two bolts on order that are M12 1.75x170P and I'm really hoping thats long enough. ><
Old 09 Apr 2015, 07:10 pm
Default Re: How to reinstall harmonic balancer?
Wow, did you read the link I keep posting for you. All this is covered. Including a part number and size for that bolt I used from fasenall. This was done so others could do this easier and with less special tools. But you have to look at and read it to take advantage of it.
You might want to get a nut and a flat washer to while your at it. That person at the fastenal doesn't know he product very well. I did have to order it and took a day to get it.
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
Old 09 Apr 2015, 07:49 pm
That will work. 10.9 M12 - 1.75X140P . Is what I used. And the directions how to use it in there to.
Old 09 Apr 2015, 08:40 pm
Flash619's Avatar
I totally didn't realize that you had listed the size of the bolt used to get it back into place. ^-^;; whoooopsie.
What are the chances of the force of the bolt pulling the pulley into place, ripping the threads from the crankshaft?
How do you torque the bolt to 100 ft/lbs when it turns? ^^;
Old 09 Apr 2015, 09:13 pm
None if you follow the instructions.
Use a bar of some type through the hole in the pulley and foul it against some thing solid on the engine while torquing the bolt.
Old 10 Apr 2015, 07:00 am
Flash619's Avatar
Can the oil pan lip support 100 ft/lbs of force against it?
Old 10 Apr 2015, 01:27 pm
Flash619's Avatar
How much force does it take to get the harmonic balancer on? They were only able to get me a medium grade bolt (not 10.9).
Just in case, I ordered one of these myself, since the people who work behind the desk apparently cant review their own inventory.
https://www.fastenal.com/web/products/details/0122026
Expedited for next day shipping, its a 67 dollar bolt, but frankly, I need this project to be finished by Tuesday.
Old 10 Apr 2015, 06:32 pm
The one you have will be fine. Run the nut up on the bolt and a washer and thread it into the crank until it bottoms out. Hold the bolt with a wrench. And crank the nut down on the balancer until it pushes it all the way on. Wipe the inside of the balancer with oil or grease before you start. A little goes a long way.
Old 10 Apr 2015, 11:45 pm
Flash619's Avatar
Nothing I can really do since the order is already shipped. And it looks like I won't be reinstalling it as soon as expected anyways with these timing mark issues.
Old 11 Apr 2015, 07:18 am
Post up some shots like I have in that help thread. That way we can see what trouble your having, If any. Will need good angled shots to see the marks line up on both top and bottom.
How to remove Harmonic Balancer? TeddoNawthCaroliney Tech & Performance Forum 17 04 Mar 2017 10:47 pm
Having trouble with pulling off harmonic balancer neuner Tech & Performance Forum 17 04 Jul 2014 07:47 am
Harmonic balancer removal Carl48 Tech & Performance Forum 6 06 Nov 2013 02:19 am
harmonic balancer Jassy General PT Cruiser Discussions 2 01 Jan 2012 12:26 pm
harmonic balancer mdskinner731 Tech & Performance Forum 10 15 Sep 2011 09:04 am
