Okay about that mystery leak
Old 10 Apr 2015, 07:45 pm
Cool Okay about that mystery leak
After the leak incident, i did look at the coolant in my 01' and it is the green stuff (that should of not been used) My question is if I get the system flushed can I put in the correct coolant or am I stuck with the wrong green stuff because that is what was used and they should not be mixed. Arrrggghhh!
(oh now I get a gurgle when i shut down ignition!)
Old 10 Apr 2015, 11:49 pm
Flash619's Avatar
Default Re: Okay about that mystery leak
I personally would just flush it all good and put in the right stuff. Not sure if I'd fully flush the block though. I've heard that can cause water pump issues with weaker bearings. Definitely drain all the green out first tho. Different coolant can have a different ph and cause adverse affects.
Though around here it doesn't matter. Every mechanic shop just throws in green, even if it still has yellow in it.
Old 11 Apr 2015, 07:58 am
You will be fine with whatever you have in it as long as it was all one kind. The difference may be the change interval. The type used will tell how soon to replace. Lots of misinformation out there on this. But Chrysler put the pink stuff in engines that don't normally use it in the overseas cars, because that was a engine they were useing in that application.
Mystery coolant leak Gorto Tech & Performance Forum 19 14 Jan 2018 12:23 am
MYSTERY jfahey General PT Cruiser Discussions 3 07 Jan 2012 11:44 pm
Overheating mystery hidinginparadise Tech & Performance Forum 3 23 May 2011 03:20 pm
More mystery..... AquamarinePT Tech & Performance Forum 3 15 Jul 2009 07:38 pm
Mystery Oil Mel K Turbo Performance 5 21 Aug 2005 09:34 pm
