temp lowering
Like Tree2Likes
  • 2 Post By Probedude
Old 11 Apr 2015, 10:05 pm
Cool temp lowering
So I go get taxes done to day and on my way there on the freeway I notice my temp gauge going lower!? What the ???
Old 11 Apr 2015, 10:08 pm
Cool temp lowering??
Driving a short time on freeway today and I notice my temp gauge is lowering ! What the hell is that? What should I do? and Can i still drive it??
Old 11 Apr 2015, 10:41 pm
Default Re: temp lowering
It is possible your thermostat has gone/is going. Usually thermostats fail and close and cause overheating, they can go open and not allow full warming up.
OR - when engine is cold. take off radiator cap and look in, if level is low, that is your problem - air is a poorer conductor than water and you're getting a false reading.
Old 12 Apr 2015, 10:12 am
If your coolant level is low you need to find out why you are loosing coolant. Recently I went to look at buying another PT Cruiser and found out that the owner had driven it without coolant by asking certain questions. He said the temperature gauge never got hot but the engine shut down. I looked at the bottom of the engine,etc and I could see indications it had overheated. Always keep your eyes on the temperature gauge and if it ever goes above or lower than the normal range you check everything in the coolant system. Never assume your gauges are telling you everything. I always check my PT Cruisers for low engine oil, coolant, brake fluid, power steering fluid, and look at the tires for low air twice a week. This only takes 5 minutes each time and can save you a tremendous amount of dollars and your spare time if you do the work yourself.
Old 13 Apr 2015, 12:42 am
Was the car cold and warming up or completely and fully warmed up when this happened?
Our PT does the same thing during the initial warm up. It's more obvious with my Ultragage hooked up.
Really simple reason - t-stat opens up and now all the cold water in the radiator and radiator hoses can travel into the engine. It hits the t-stat, lowering the temp and closing it and you see it on the gauge. Completely normal.
JoeX and buddyiramae like this.
______________________________________________
Most misunderstandings in the world could be avoided if people would simply take the time to ask, "What else could this mean?
2001 PT Cruiser LE 5 spd, original owner, no mods, MOOG arms with spherical bushing (ride is now a bit harsher vs OEM)
- 109K replaced timing belt/WP/tensioner/idler/crank&cam seals with same 1st gen design. That was a fun day and half!
- 119K Gates water pump failed after only 10K miles. Replaced with Airtex. This time around it was a 7 hour job.
2001 PT Cruiser LE AT 59K miles. Bought used, newest addition to the family
Old 13 Apr 2015, 09:54 am
If the car is getting cooler, and I assume not in a normal way Then your thermostat is sticking open or your guage / sensor is bad.
Pull the thermostat and see if it is fully closed. Then boil it in water and check if it opens. If it is old just put a new one in. Get a good one. Make sure you replace the gastket.
Good Luck
Mike
FS EIBACH LOWERING SPRINGS, ROAD MAGNET LOWERING SPRINGS jamie_hildebrand Classifieds: For Sale/Trade 1 10 Nov 2013 10:09 pm
car temp goes hi wen AC on? notime0075 Tech & Performance Forum 6 08 Aug 2013 05:14 pm
Temp sensor azphotog General PT Cruiser Discussions 2 17 Jan 2010 11:22 pm
temp guage cruiser12 Tech & Performance Forum 0 04 Nov 2004 03:43 pm
oil temp brngrhd General Turbo Discussions 0 17 Mar 2004 12:53 am
