Low compression?
Like Tree22Likes
Old 15 Apr 2015, 12:11 pm
Default Low compression?
Hi, all.
First time posting. I have a 2004 PT cruiser 2.4L with 110K.
My car has been idling VERY rough for the past month or so, and had a flashing check engine light when idling. Code is P0300 and P0304. I had work done on it, first they thought it was spark plugs. Wrong. Then they thought it was the ignition coil. Wrong again. They now think I have to get my head gasket replaced or overall my whole engine. They said my compression is around 100 on all cylinders except #4, which is at 90. Apparently it's supposed to be at 175?
Any help??
Old 15 Apr 2015, 12:43 pm
LionPT's Avatar
Default Re: Low compression?
If their next step is to replace the head gasket or the engine...take it to another shop.
soyomb and UptownSport like this.
Old 15 Apr 2015, 03:05 pm
Doesn't seem they know what they are doing let alone a compression test. I'm with Lion.
UptownSport likes this.
Old 15 Apr 2015, 04:09 pm
cruserdad1976's Avatar
before i spen another penney id get a diffrent mech they cant tell plugs and a coil from the motor??? or a head gadgasket???? seriously
here are a few questions
Did you get it HOT--Overheated??
was the fans both working like they should??
do you have AC
do you have to add coolent often??
and I dont have the specs in frount of me but if ALL $ CYLENDERS are the same do you really think that alr all LOW ON COMPRESSION???
rob342 and Handy_Cruiser like this.
Old 15 Apr 2015, 04:13 pm
what does "VERY rough" mean? can you post a video? did it start after a major repair, like a timing belt?
dont worry about the compression numbers they gave you. they likely aren't doing it right anyways. they should do it with the motor at operating temperature and the throttle body open. i'd guess the numbers are low because they didnt have the throttle body open, and that #4 was a lower number because by the time they got to #4, the engine had cooled.
reading your post, you didn't take it to a mechanic. you took it to a parts changer. the difference here is a mechanic would EASILY know if a coil was bad without replacing it, a mechanic wouldn't think a measly 10psi difference in compression meant something was terrible wrong, and a mechanic would test parts before making you buy new ones.
you need to tell us when the problem started, what you've had done to the car before and after it started, and if possible, post a video showing the rough idle.
be sure to let us know about any other info you have, like did it get worse after the coil or plug replacement.
please let us know your mechanical skills, the common cause of your problem is a leaky intake gasket. idiots changing parts can mess the gaskets(or your intake) up pretty easily. they took it off to do the plugs, coil, etc. you can check it with starting fluid to see if it revs up if when you spray it if you're knowledgeable enough to do an oil change. if not you might spray too much and cause a nice fire. so please let us know your mechanical skills. as Cruiserdad1976 said above, a bad cooling fan will also cause a rough idle.
also, please add your location to your profile.
cruserdad1976 likes this.
Old 05 Feb 2018, 04:23 pm
I had completely forgotten about this thread, so I'll give an update, for as much as I can remember.
Spark plugs were incorrectly gapped. Got a tune up.
My motor mounts were wrecked (found that out myself, not a single mechanic noticed it)
Changed both of my 02 sensors.
And (recently) had a leak in my solenoid pack, so got that replaced.
The outcome of all of this, no check engine light!
Now, this was all done over the course of the past year or 2, so, it was a long struggle, but I made it.
Old 05 Feb 2018, 04:25 pm
rob302's Avatar
that's funny. i don't even remember writing my reply. thanks for coming back to update us
Fk5 and Handy_Cruiser like this.
Old 05 Feb 2018, 05:15 pm
Plug gap is 0.050 " , the plugs would need to be closer to 0.250 " to cause a problem. There may have been other issues covered during the tune up.
Or saw and wasn't going to tell the car owner.
A: Car comes in for an engine light on, shop sees bad motor mount tells car owner. Car owner says " You are just trying to sell me parts. " then storms off to bad mouth shop."
Or
B: Car comes in for an engine light on, shop concentrates on check engine light. Shop may or may not see bad motor mount and does not tell car owner. Car owner later says " Why didn't they see the bad motor mount?"
If the car owner isn't a regular to the shop, there isn't a way to tell if A or B will play out so the safest bet is B even though both choices are a loser for the shop.
Old 05 Feb 2018, 05:25 pm
Fk5 Fk5 is offline
Or
Seriously?
Could the shop have told him that his motor mounts looked bad and given him a price if they wanted them to change them out? They could let him know that it isn't going to change the problem that he came in for and that there is no reason to drop new motor mounts today if he is going to need a replacement engine (low compression) tomorrow. The shop I go to often gives me lists of things that have to be done and things that should be done. They don't start any work without my approval. Not sure how that hurts the shop. It shows they are attentive without demanding work.
2003 GT 5 speed
162,000 miles
Old 05 Feb 2018, 05:53 pm
Or
I should have included this to clarify. But, when I initially took my car in to get looked at, I ALSO mentioned that the idle was rough, and would rock/shake my car up quite a bit. Ever since I changed the motor mounts out, it's so much better. I was a regular to this shop, I was the "guy with the PT Bruiser". Not sure if they just overlooked it or what.
But hey, it's taken care of now. Only problems I have right now are:
1) Oil pressure switch replacement (Oil leaking, oil pressure light comes on at low rpm/when stopped, turns off when I'm driving)
and
2) ABS and TRACOFF lights came on. But they'll turn off after a while, and randomly come back on. Hoping a sensor?
Tags
compression, rough idle
Compression Papa2448 General PT Cruiser Discussions 12 10 Jan 2016 12:15 am
compression loss ohioptdriver Tech & Performance Forum 15 04 Nov 2013 10:45 pm
No Compression in Cyl 4 WildBronco General Turbo Discussions 3 24 Oct 2013 04:14 pm
compression psi moonshinehd Tech & Performance Forum 7 27 Apr 2012 10:03 pm
Compression ptnut Tech & Performance Forum 12 21 Nov 2011 11:40 am
