PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   General PT Cruiser Discussions (http://www.ptcruiserlinks.com/forum/general-pt-cruiser-discussions/)
-   -   Gas filler restrictor replacement???? (http://www.ptcruiserlinks.com/forum/general-pt-cruiser-discussions/56493-gas-filler-restrictor-replacement.html)
gwairbrush 20 Apr 2015 05:02 pm
Just noticed the flap door at the top of the filler neck is gone. I may not be able to pass a smog test here in calif. without it. Are those removeable/replaceable without replacing the whole filler neck?
I have 2007 Limited turbo...my understanding is that the filler neck cost about $256,000 at the dealer......
LionPT 20 Apr 2015 05:10 pm
Re: Gas filler restrictor replacement????
I'm not positive...Nitro will know for sure...but in the G2's, I think the flapper is either located at the tank or discontinued altogether.
NitroPT 20 Apr 2015 05:31 pm
The anti theft flap is a none serviceable part. The fuel filler tube is easy to replace and only about 50-65 dollars?
It is not part of the visual for an CA emission test.
gwairbrush 20 Apr 2015 06:29 pm
Thanks Nitro! Appreciate it.......
dalandon 21 Apr 2015 01:02 am
My fill neck is the same, no problems with smog here in cali
