07 PT Cruiser No Brake Light and Tail Lights
  • 1 Post By ptcruisersteve
Old 21 Apr 2015, 04:23 pm
Default 07 PT Cruiser No Brake Light and Tail Lights
On my 07 PT Cruiser my brake light and tail lights stop working while I'm driving and my one headlight and one hazard light stays on. The only way the one head light and hazard light turn off is when I turn the car off and take the key out. I changed the multifuction switch and it didn't do anything. Somebody told me try to change the brake light switch or probably the TIPM. HELP ME PLEASE!!!!!!
Old 21 Apr 2015, 08:20 pm
Default Re: 07 PT Cruiser No Brake Light and Tail Lights
I would suggest to look at your TIPM. You might try disconnecting the battery cable on the negative side, turn on your head lights, turn off your headlights, wait 5 minutes, put the battery cable back on and see if that helps. I have an 2007 PT Cruiser and also am leaning towards the TIPM as being my problem also.
Have you taken a voltmeter reading to see if you have voltage going to the brake switch and taillight sockets?
Ray_Dockrey likes this.
Old 22 Apr 2015, 07:59 am
Thanks for reply ptcruisersteve.......... yes i did check the voltage and its fine. So i will do what you suggested. I will let you know what happen.
2005 PT Dream Cruiser - Brake and Tail Lights Stopped Working ArkansasTraveler General PT Cruiser Discussions 5 10 Aug 2015 07:42 pm
No Brake lights or tail lights/running lights kitzmann56 General PT Cruiser Discussions 8 14 Feb 2015 03:07 pm
TAIL LIGHTS ND BRAKE LIGHTS NOT WORKING mccloud12 Tech & Performance Forum 7 12 Jun 2014 06:21 pm
HELP! '02 Cruiser with no tail lights, then no brake lights. tschauer Tech & Performance Forum 1 16 Sep 2010 05:54 am
Why do my tail lights and dashboard lights only go on when I brake? bodykits Exterior Accessories Forum 1 16 May 2009 07:28 am
