Cooling Fan Assembly
Like Tree5Likes
Old 25 Apr 2015, 09:46 am
Default Cooling Fan Assembly
I have a 2006 PT Cruiser (non turbo) and I need a cooling fan assembly. The problem arises when I look on Advance Auto Parts (where I work, so I get a discount) there is two assemblies without controllers (do I need controllers?), but one comes with a 4/pin harness with relays (it literally shows 3 pins on their website though) and the other with 3/pin harness and no relays. There is also a 4 prong SQUARE connector assembly at RockAuto.
So confused. I'm no car expert obviously, but I have done routine repairs. Is this something I can walk outside and unplug it and just check the prong connector? How hard is it to replace it? Assuming I can even find the correct assembly.
I can post links if needed, but it says I would have to wait for mods to accept it I assume. Just let me know, thanks.
Also how bad would it be if the timing belt has never been changed in 148k miles?
Old 25 Apr 2015, 09:57 am
Default Re: Cooling Fan Assembly
You can do this two different ways.
You can go to the dealer with your VIN # and they will tell you exactly what radiator fan you have in your PT Cruiser.
Or you can get under the PT Cruiser and look at the radiator fan connector. IF you have a grey plug you have the four pin connector. If you have the black plug you have the three pin plug. You should be able to see the radiator fan relays on your PT Cruiser that are attached to the radiator fan housing. I would recommend unplugging the radiator fan just to make sure what number of pins you have.
It only take about an hour to replace it and there are threads on how to replace the radiator fan.
I would recommend you introduce yourself to the forum and include some details of your PT Cruiser.
Old 25 Apr 2015, 10:10 am
This is from the earlier model cruisers but basically they are the same. In the picture, you can see the fan electrical connection that needs to come apart. You can check to see the wires.
Also, from the earlier models....
Removing the fan and housing 01-05 PT
Old 25 Apr 2015, 11:08 am
LionPT's Avatar
I believe the G2's 2006-2010 all have the 4 pin square connecter.
Old 25 Apr 2015, 11:50 am
I could not make this statement because there are some 2006 PT Cruisers that are manufactured in 2005 and I am not sure of when they switched over to the 4 pin square connector.
Old 25 Apr 2015, 12:48 pm
LionPT's Avatar
Mine was made in Aug 2005 & is square 4 pin.
Old 26 Apr 2015, 12:55 am
Thanks everyone. Ill take a look under it today and see which prong connector it is. After watching that YT video it doesn't look that hard at all. Will just do it myself.
Old 26 Apr 2015, 02:09 am
I would suggest making sure you remove the battery and the battery support plate to make it easier to remove the radiator fan. This will ensure the radiator does not get damaged removing the old radiator fan and installing the new radiator fan.
Old 26 Apr 2015, 11:27 am
I replaced mine (also an 06) last year, it had both a 3 prong and square 4. so either one should work.
'06 Cruiser Touring, 157k, Cool Vanilla, Auto
Old 26 Apr 2015, 11:58 am
06OregonCruiser,
Can you post when your 2006 was manufactured on the driver's side door?
2003 Turbo cooling fan assembly CruiserSTL General Turbo Discussions 2 21 Jan 2014 06:50 pm
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
RADIATOR AND FAN ASSEMBLY ALBERT Feedback and Support 2 15 Sep 2012 09:57 am
Fan Assembly bnicolet General PT Cruiser Discussions 1 27 Feb 2011 05:01 pm
Headlight assembly for the PT cutter Exterior Accessories Forum 6 02 Jul 2003 07:04 pm
