I just replaced the rack and pinion assembly on my 2006 pt but did not realized that I purchased and installed the assembly that came with the power steering switch outlet, and my original steering rack does not have the power steering switch. How do I plug this outlet as it is leaking fluid?
Thanks for your help |
If I'm understanding you correctly, the new assembly comes with the switch that you don't need and it's leaking? You can buy a new switch that doesn't leak, or try and measure the threaded hole that the switch fits into and buy something that will screw into that hole where the switch went.
Is it leaking where the switch screws into the assembly? If so, about about some plumbers tape to wrap around the threads and stop it leaking? ![]()
Rules of the forum have been updated as of *07/07/2019* Please read them over. - All decisions by the Moderator are semi-permanent, can and may be changed at his discretion but definitely will be the final word. Any action performed by the Administrator or Moderators are not to be discussed on the forum. Last edited by CREWZIN; 26 Apr 2015 at 09:16 pm. |
I would buy the missing switch and install it as a plug.
Teflon tape is generally frown upon in automotive applications. It can cause fittings to loosen if you use to much, and if it gets in the system it can cause other issues. It's OK to use a small amount on a pipe thread (tapered) fitting, but anything that screw's straight in is generally sealed with a flared line or an o-ring. I'd guess the switch would be the o-ring. Easiest way to get the right size plug would be to buy the switch and screw it in. You might look around for cut wires or a hidden connector. Seems strange there wouldn't be a pressure switch on your car. The purpose of the switch is to help with idle quality when the pump causes strain on the engine at idle Last edited by rob342; 26 Apr 2015 at 10:30 pm. |
Thread Tools | |
Display Modes | |
Power Steering Pressure Switch | CherylK | Tech & Performance Forum | 2 | 12 Oct 2011 03:03 pm |
Power Steering Switch | navydave | Tech & Performance Forum | 9 | 11 Jan 2011 11:04 pm |
Power steering switch | hfddirty30 | Tech & Performance Forum | 5 | 29 Aug 2010 06:18 pm |
Power steering switch | Franksredpt | General PT Cruiser Discussions | 2 | 06 Oct 2009 11:53 am |
Power Steering Switch | souljha | Tech & Performance Forum | 3 | 13 Feb 2009 02:13 pm |
