Starter problem? Relay problem or others?
Old 28 Apr 2015, 12:17 pm
Default Starter problem? Relay problem or others?
It is a 2006 touring, 2.4L NA
Sometimes when I turned the key, I heard only only 'click' sound, nothing happened, then I turned it again, the engine started.
This happens once every few days.
Is this possibly a starter problem or starter relay problem, or others?
Any suggestion is appreciated.
Thanks
Old 28 Apr 2015, 12:45 pm
Default Re: Starter problem? Relay problem or others?
sounds like a connection issue. i'd start by cleaning and inspecting the battery cables on both ends. a little labor, but it's free
Old 28 Apr 2015, 08:12 pm
How old is the battery?
You might want to consider getting an battery load test on it just to make sure it 's not the battery before looking at the starter.
Old 22 Jun 2015, 05:52 pm
I had the same issue, turned out to be a bad negative battery cable. I changed it in the autoparts store parking lot.
A relay or starter problem? or other? postbeauty General PT Cruiser Discussions 24 10 Dec 2014 10:40 pm
02 PT Cruiser Starter Problem? Maybe? KevinKnuth Tech & Performance Forum 4 10 Jan 2014 06:22 pm
05' PT cruiser 2.4T .. starter problem? fresh_duude Tech & Performance Forum 3 22 Jul 2013 08:45 am
ASD Relay & Electrical Problem sakmerlin37 Tech & Performance Forum 5 06 Jun 2013 09:40 pm
Starter/Solenoid problem worseforwhere Tech & Performance Forum 5 23 Sep 2008 02:11 pm
