Cut Grounding Wire behind Right Front Tire
Like Tree3Likes
  • 1 Post By myckee
  • 1 Post By rckstein
  • 1 Post By CREWZIN
Old 30 Apr 2015, 07:48 pm
Smile Cut Grounding Wire behind Right Front Tire
Our horn went off w/o ceasing. The fixit guy at Autozone said it was the horn, not sure why, disconnected the horn after reaching thru some sort of internal wheelwell plastic, disconnecting the cover and unplugging the horn.
That left the reason why.
I figured the 4 post thing in the horn thread was the horn switch. I guess I need to replace it.
But, behind the right front wheel was a post with a cut wire connected to it he said. No other leads coming off of it. Anyone know what it is? What grounds behind the front right tire?
Old 30 Apr 2015, 08:39 pm
Default Re: Cut Grounding Wire behind Right Front Tire
I would suggest taking a picture of it and posting it.
Old 30 Apr 2015, 10:02 pm
I believe he is talking about the ground wire that attaches onto the strut. That ground wire is there to provide a ground for the wheel bearing. Without a ground, the wheel bearing will wear out faster.
Old 01 May 2015, 07:47 am
rckstein's Avatar
Like the one in the pic below. Sorry "CREWZIN" borrowed this pic off the internet. It's the driver side but there is a similar wire on the passenger side.
Old 01 May 2015, 08:43 am
Here's the thread that discusses ground wires on the PT...
ground wires from body to front struts?
Old 17 May 2015, 06:41 pm
Smile Re: Cut Grounding Wire behind Right Front Tire
That is what it was. Thank you! I had two missing bolts for the car wheel, and this prolly added to the bearings and general tire wear.
Old 29 May 2015, 03:36 pm
Okay, according to Lithia, the above pic shows the sensor wire for the ABS. We have not had any abs lights go off. Guy said it had to be a certain length, it has two wires inside.
But, my Haynes manual, on page 10-4, in illustration 2.4, shows the ground strap bolt to the left of the ABS Harness bolt, proving the above kind poster correct.
I want to find the correct gauge wire for that ground strap bolt. Connects with a flat strip of metal to a caplug rubber insert.
Any hints, answers?
Old 29 May 2015, 05:07 pm
Any hints, answers?
There no correct length for the ground strap. Different gauge wires will work as it's only a ground. 6,8,10,12 gauge will all work. A decent hardware store will have different ends that you can solder to the wire for a good connection. If you still have the ground strap on yours that's cut, you could probably even solder the two cut ends together to make it whole again.
Old 29 May 2015, 08:07 pm
The reason the ground wire to the strut breaks is its not flexible enough to withstand constant up and down motion. The strands are to thick.
If you replace it with factory or solder the pieces together the same thing will happen.
You will have better luck if you can use copper wire with more strands or a braided wire with the proper ends to attach it.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 29 May 2015, 09:03 pm
Sorry Joe, I don't go along with your theory. Mine and most of the grounding wires have been on for a long, long time (mine 15 years) without breaking. I think most find their wires CUT, probably by the mechanic who's replacing the front struts or part of the suspension and too lazy to take them off, so "snip" goes the grounding wire.
Look at my picture. Plenty of wire for any kind of movement without stretching/breaking it.
02PT: Blue wire in front wheel wells? 02PurplePT Tech & Performance Forum 16 24 Jul 2017 04:49 pm
right front tire making a noise Purevil Wheels, Tires, Suspension 4 26 Mar 2011 09:42 am
Tire noise front end..... AZCruiser26 Wheels, Tires, Suspension 5 19 Sep 2009 02:14 pm
front to back tire rotation links Wheels, Tires, Suspension 17 27 Dec 2004 06:12 pm
correct speaker wire harness for front speakers Curruzr General PT Cruiser Discussions 4 12 Aug 2004 04:01 pm
