Rough idle when AC is on
Like Tree2Likes
Old 01 May 2015, 12:46 pm
Default Rough idle when AC is on
Edit: 2006 Pt Cruiser 140k miles
So I have this problem where if the AC is on when idling (sitting at a light for example) the engine bogs down a lot. It has stalled out once, but with it getting hotter I'm sure it will get worse.
I took it to a shop I trust and they said the AC was getting to over 450 psi (or whatever) and the engine would start to bog down. The cooling fan needed replaced. I'm paraphrasing here of course, so not sure if that makes sense.
I started to do my own experiments and sure enough if the AC is on at idle the fan will NOT turn on until it gets just over the half way mark on the temperature gauge. When the fan turns out it blow out cold air and the idling turns back to normal. A minute later the fan will cut off and back to getting bogged down after 15 seconds and just keeping at it every 15 seconds or so. Two minutes later when the temp gauge gets back to just over half the fan will turn back on and it repeats this process indefinitely.
The fans don't cost too much ($100 or there abouts), I just want to make sure this is the cause. I mean the fan is working. It turns on. At "low" or "high" speed I have no idea.
It just seems like the fan works but only when it hits half way mark on the temp gauge. Then cools the engine then goes back off then the AC starts to bog down the engine. So is it the fan? It seems to be working correctly, but it would make sense if it worked all the time not just at the half way point on the gauge and everything would be perfect.
Old 01 May 2015, 12:51 pm
Default Re: Rough idle when AC is on
Check that the fan is running when the AC is on. If not that's your problem. Also air idle control valve.
Old 01 May 2015, 01:03 pm
It only runs when the temp gauge needle goes a bit above half way point. Then for a minute it runs fine then it (the fan) turns off then bogs down excessively.
Old 01 May 2015, 01:56 pm
When the ac is on it should run all the time. There are two sides to the fan. Low and high. Your high is working. But to be sure it's the fan you can run a jumper to both sides of the fan to see if one still not working. That will rule out othe possible causes. The ground pin is the middle one. If one side doesn't run. Buy you a fan. I wouldn't run the ac until you get this fixed.
Old 01 May 2015, 08:22 pm
Thank you. Would some alligator clips clipped to the battery work or would I need some kind of multimeter? Does the car have to be on if I use the actual battery to test the fan?
Old 01 May 2015, 09:36 pm
I would suggest getting a new radiator fan. The radiator fan are one of the most common parts on the PT Cruiser that needs replacing. On my PT Cruisers I replaced the first one at 70,000 miles. With your PT Cruiser at 140,000 miles its a good chance you are due for the third new radiator fan. Its a peace of mind having a new radiator fan in your PT Cruiser only costing $84.00 knowing that you have a better chance of not overheating the engine. I even have a brand new one in the garage in case one of my radiator fans start to give me a hint of going out.
Old 03 May 2015, 03:49 pm
Thanks for the help guys. I just bought a new fan for $95 with shipping. Affordable IMO.
Old 03 May 2015, 05:03 pm
767skyking's Avatar
As Danny stated... Fan should run all the time when wheels are not turning. Check your speed sensor.
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 03 May 2015, 08:48 pm
Radiator fan operation is controlled by the Powertrain Control Module (PCM) with inputs from the temperature of the coolant, which is sensed by the coolant temperature sensor, and vehicle speed, which is measured by the vehicle speed sensor.
P0480 - Low Speed Fan Relay Control Circuit
Ground Circuit
Low Speed Rad Fan Control Circuit Shorted To Battery Voltage
Low Speed Rad Fan Control Circuit Open
Low Rad Fan Control Circuit Shorted To Ground
Radiator Cooling Fan Module
Totally Integrated Power Module
P0481 - High Speed Fan Relay Control Circuit - An open or shorted condition detected in the high speed radiator fan relay control circuit.
Possible causes on the 2006 model year and later include:
Fused (B+) Circuits
Ground Circuit
High Speed Rad Fan Control Circuit Shorted To Battery Voltage
High Speed Rad Fan Control Circuit Open
High Speed Rad Fan Control Circuit Shorted To Ground
Old 03 May 2015, 08:53 pm
767skyking,
Excellent point. If the speed sensor was bad wouldn't it also be effecting the
speedometer and transmission?
Stalls at idle. Sometimes. And rough idle scatgo1 Tech & Performance Forum 6 27 Nov 2014 11:04 am
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
'07 PT - Rough Idle, rough acceleration, and shuts off if it idles for too long La_Bruja Tech & Performance Forum 3 09 Aug 2013 07:50 am
Rough Idle only with AC on beachpatty General PT Cruiser Discussions 2 02 Oct 2009 07:11 am
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
