General check engine light information
  • 1 Post By zipps
Old 02 May 2015, 02:38 pm
Default General check engine light information
[B]Just wanted to pass on some check engine light issues to those who want it. The computer has several features built into it. If you have a code showing and you cannot clear it by a reset or by disconnecting the battery I have found that it is caused by a major malfunction most likely a direct short in the harness or sensor it is important to carefully inspect each wire for damage. The check engine light will flash 10 times (Key on non running Position)whenever the power to the car has been disconnected. It should stop when the computer completes a full cycle check and no malfunction is detected. The car will not pass a smog inspection until the light stops flashing. If the light is flashing while driving this is a warning to check the car asap. I have found and see it all the time rodent damage is the cause on the wiring (I know sounds crazy) Chewed wiring will cause the computer to throw a false code a bad oxygen sensor code such as P0038. When you replace the sensor it still shows the code. If you are replacing parts according to the code and it is not clearing the code inspect carefully the harness. Chewed harness with exposed wires can short and destroy the ECM. If you have a check engine light that you cannot shut off most likely this is the cause.[/B]
Old 02 May 2015, 02:47 pm
Default Re: General check engine light information
Photo of wire damage 02 sensor bank1 sensor 2
buddyiramae likes this.
Question about check engine lights/codes and general maintenance CruisingBlind Tech & Performance Forum 31 03 Jan 2015 12:53 pm
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
