Torque Specs needed!!
Like Tree2Likes
  • 1 Post By CREWZIN
  • 1 Post By DrummerJoel
Old 03 May 2015, 11:29 am
Thumbs up Torque Specs needed!!
Hails, if anyone knows or have the list of torque specs from a PT Cruiser 2003, please let me know. I need to change ball joints, both lower control arm bushings, inner & outer tie rods etc. The whole area "make over". I need to make sure I'm doing it correctly, not only mount them and keep walking.
Thanks for your time
Old 03 May 2015, 12:11 pm
Default Re: Torque Specs needed!!
Have you tried looking into the shop manual
Free 01-04 PT cruiser shop manual
Old 03 May 2015, 12:37 pm
If that link don't work, try this....
JustCloud : OEM Service Manuals
3rcruiser likes this.
Old 05 May 2015, 12:35 pm
Just what I was looking for, thanks.
Old 05 May 2015, 12:36 pm
I have that..and no luck
Thanks
rob342 likes this.
Old 05 May 2015, 01:03 pm
ball joints,
from alldata:
Ball Joint Stud Pinch Bolt 70 ft. lbs.
control arm bushings: With no weight on the lower control arm, tighten the lower control arm rear pivot (and suspension crossmember) bolt to a torque of 250 Nm (185 ft. lbs.) , then tighten the lower control arm front pivot bolt to a torque of 170 Nm (125 ft. lbs.).
Tie Rod Adjuster Jam Nut 55 ft.lb
Tie Rod Steering Arm Nut 40 ft.lb
Tie Rod Jam Nut 55 ft.lb
Old 05 May 2015, 04:19 pm
Old 09 May 2015, 10:09 pm
Originally Posted by rob342 View Post
from alldata:
Thanks for been specific. What about the inner tie rod torque?
Old 09 May 2015, 10:42 pm
Thanks
http://www.ptcruiserlinks.com/forum/...op-manual.html
Thanks
Hmmm I checked the shop manual and the information is on page 29. It helps when you learn to find the right key words.
Tags
torque specs
Torque Specs UZ4PLAY Tech & Performance Forum 15 02 Aug 2012 12:30 pm
Torque specs hidinginparadise General Turbo Discussions 1 19 May 2011 02:32 pm
torque specs gokart Tech & Performance Forum 2 15 Apr 2009 01:46 pm
torque specs? youngcruiser Tech & Performance Forum 8 21 Mar 2006 03:49 pm
Torque Specs irelandmoss Tech & Performance Forum 2 18 Jan 2006 09:07 am
