No Crank No Start!!!
Old 04 May 2015, 06:09 pm
Default No Crank No Start!!!
I bought my 02 cruiser off of an older lady the vehicle has 72,xxx miles on it and when i got it, it was giving code p 0601 scrubbed the ground wire code went away for a few days code came back but car drove fine. Then the other day i drove to work everything was fine, went to leave for work turned the key and nothing but a couple beeps and the airbag light and no check engine light left key in on position and check engine light came back on. code reader could o not connect to ecu. hours later went back to car started right up. it seems that if i let it sit it will fire right up. checked starter its fine replaced ignition switch and actuator pin worked perfect for a few days and then today got to work and nothing. jumped started and it spun the motor but no fire was thinking pcm was malfunctioning any thoughts?
Old 04 May 2015, 06:31 pm
Default Re: No Crank No Start!!!
That's what the code says:
OBD-II Trouble Code: P0601 Internal Control Module Memory Check Sum Error
Old 04 May 2015, 06:51 pm
any idea why i can wait some hours and then it starts right up i drive it and then when i get home and try to start nothing
Old 04 May 2015, 07:30 pm
A cold / cracked solder joint may cause this, it moves with temperature or stress.
Makes contact sometimes, sometimes not.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
no crank no start PLEASE HELP ljw14 Tech & Performance Forum 29 26 Mar 2015 07:39 pm
Crank no start diamond_64 General PT Cruiser Discussions 13 20 Jan 2015 11:42 pm
CRANK BUT NO START clifford General PT Cruiser Discussions 3 27 May 2014 11:15 pm
crank no start 69charger Tech & Performance Forum 13 18 Sep 2013 07:04 am
