2006 touring non-turbo, 98K miles
The manuals says changing atf is not necessary under normal usage. However, I noticed the trans jerks when shifting from 1st to 2nd gear, other gears are fine. Another situation is , when I slow down, say when making a turn, then I press gas pedal to accelerate again, the jerk is very strong, just like being kicked by someone from the back. Is the transmission dying? Should I change the atf to mitigate the jerks? any suggestion is highly appreciated thanks |
![]() Quote:
The "Three Amigos" (And Growing) Performace, Body and Service, OEM "Team Amigos FREE Parts!! PM me for details!! ![]() |
Sounds like you have some bad motor mounts.
It is tricky here.
When I slow down and then accelerate, if I press the pedal very very gently, then nothing happens; otherwise the gear shifts (I guess it is from 1 to 2), the jerk is strong. It is basically like the experience when I first learned to drive a manual transmission, the shifting is rough because I can not shift in the right speed and rpm. |
![]() Quote:
Do you use RTV on the pan? Or have you found anything that works better? Seems like well cured RTV still allows fluid seepage. Thanks! BigAng 2002 Touring Edition 122k and counting! |
![]() Quote:
I may just replace the pan next time I change the filter.
Thanks 767! BigAng 2002 Touring Edition 122k and counting! |
![]() Quote:
Thread Tools | |
Display Modes | |
changing ECU | texasjoe | Tech & Performance Forum | 12 | 08 Dec 2014 02:59 pm |
Changing TCM and PCM together | Benodom | Tech & Performance Forum | 0 | 26 Dec 2010 11:35 pm |
Changing PCM and TCM together | Benodom | Tech & Performance Forum | 0 | 26 Dec 2010 11:22 pm |
Changing wires | Scrathy | Tech & Performance Forum | 4 | 25 Aug 2009 08:17 pm |
changing oil | tm05cruiser | Tech & Performance Forum | 1 | 31 Oct 2007 12:10 pm |
