noise in front end
Old 07 May 2015, 09:03 pm
Default noise in front end
going down the highway straight my stering wheel is turned about a inch and a half. It makes a humming noise just going down the road like power stearing noise or a tire.The min I turn the wheel straight the noise leaves but the car starts going to the right.Can anyone tell me what this is. Do you think a cv joint or a outer bearing in the front end.
Old 08 May 2015, 12:36 am
Default Re: noise in front end
Please introduce your self and tell us a little about your PTC
Sounds like wheel bearing, you need to have your front end repaired ASAP.
Are you able to do any work yourself?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 09 May 2015, 06:22 pm
Yes I am a mechanic. I had the car on the rack and turned the wheels and did not feel anything loose or rough. Could it still be the bearing?If it is the bearings I will order them.
Old 09 May 2015, 07:16 pm
Pulling to the right is something else. Alighment or worn boll joint or tie rod. Bought a stratus with a bad bearing. Sounded like an air raid siren at fifty five. But ran true.
Old 11 May 2015, 07:55 pm
I did alien the front end all good. The wheel must not have been straight. Still have humming on passangers side when I turn left. Any ideas
Odd Front end noise. pluminator Wheels, Tires, Suspension 3 12 Dec 2012 03:30 pm
Front end noise nevalicous Wheels, Tires, Suspension 2 29 Apr 2012 03:30 pm
FRONT END NOISE??? help mjb457 Tech & Performance Forum 3 13 Mar 2010 12:41 pm
Front end noise mheff Wheels, Tires, Suspension 9 18 Nov 2009 11:37 am
?? Noise From The Front :( hicomp Wheels, Tires, Suspension 7 17 Oct 2008 02:36 pm
